| Author |
Message |
abrahamseven Regular
Joined: 14 Aug 2009 Posts: 44 Location: Fruitland Idaho
Posted: Fri Oct 05, 2012 7:56 pm Post subject: JD M Fan Hub |
Ok, I bought a new Fan Hub for my John Deere M Model from the Smart Farmer on e bay, I just got around to installing it. Well, I will be darn, it is about 1/8 inch too long and the fan rubs on the radiator. My question is Where can I buy an original one new or have my old one fitted with a bearing so it won't need oil . I have tried o rings and such and it still leaks, I am at a loss. Any Ideas? Appreciate any comments.
steve |
| Back to top |
Hotflashjr Tractor Expert
Posted: Sat Oct 06, 2012 3:33 am Post subject: Re: JD M Fan Hub |
Is it the fan they are selling on there that isn't stock and looks like
its off a kubota diesel?
Your local machine shop should be able to help you out and do
something to fit a sealed bearing in there one way or another. I
would think you would have to do some welding or changes to an
original fan assembly to make it work. I can't remember anyone
posting on here they have done that before. |
| Back to top |
leon Tractor Expert
Posted: Sat Oct 06, 2012 4:04 am Post subject: Re: JD M Fan Hub |
As I recall I had a problem like that on my Super C Farmall when trying to use a new-manufactured will-fitter's hub with sealed bearings. I ended up returning that and got a replacement original hub. Incidentally, the hub in my Deere MT, and probably your M, look exactly like the one in my Super C. Follow the operator's manual for filling and draining the excess oil out of the hub and you may not have a problem |
| Back to top |
Tech 7 Long Time User
Posted: Sat Oct 06, 2012 4:45 am Post subject: Re: JD M Fan Hub |
Too late to help you now but the one I bought from this site a number of years back fit and worked well. |
| Back to top |
James Howell Tractor Guru
Joined: 06 Mar 2006 Posts: 5804 Location: Hutchins, TX
Posted: Sat Oct 06, 2012 5:28 am Post subject: Re: JD M Fan Hub |
Replaced the fan assembly on "Sam" one of our 51MTs.
Bought a new fan assembly from Sharp's Tractor.
It was a simple bolt on replacement.
Filled it with oil and no leaks to date.
Used Gates fan belts.
Hope this helps. |
| Back to top |
Mike M Tractor Guru
Posted: Sat Oct 06, 2012 9:12 am Post subject: Re: JD M Fan Hub |
I think M & MT fans might be different and the repops may
not make both? I posted on here several times the oil seal
number I expoxed onto the back of my M fan and it sealed it
up. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
