| Author |
Message |
Jetbird Regular
Joined: 29 Jul 2012 Posts: 94 Location: Central Massachusetts
Posted: Fri Oct 05, 2012 8:12 pm Post subject: Wiring harness |
My Ford 3400 3 cyl gas has had its wiring harness eaten by mice. The New Holland official parts site names it C9NN14A103B for the front harness and C5NN14N104R for the rear. This site lists a harness under the first number that replaces both front and rear, but says it is for diesel tractors not gas. The New Holland website lists only one set of numbers so is the harness the same for both diesel and gas? I can't buy the dealer wire set since it totals $250 for the front and rear, vs. $43 for both on this site... any info appreciated. |
| Back to top |
Greg Wolodkin Long Time User
Joined: 02 Oct 2007 Posts: 534 Location: Massachusetts
Posted: Sat Oct 06, 2012 3:23 am Post subject: Re: Wiring harness |
Hey Jetbird -
It's pretty easy to either make a new one or (more likely) simply repair any sections that have been damaged. I've got the wire, the marine grade crimp connections and a decent set of crimpers if you want to go that route. I've done that job on two other Fords of the same vintage and there just isn't much wire to run.
The one exception on the gasser might be the resistance wire. Mine was in good shape so I re-used it. I think that could simply be replaced with a coil resistor if necessary, or you could maybe switch to a coil with the resistance built in.
Let me know -- I'm due for a visit out your way anyway and after this weekend things should be settling down a little.
Greg |
| Back to top |
Ultradog MN Tractor Guru
Joined: 22 Apr 2001 Posts: 12440 Location: Twin Cities
Posted: Sat Oct 06, 2012 3:24 am Post subject: Re: Wiring harness |
Buy the diesel one from this site.
The only difference between the gas and diesel harnesses is the diesel has a big 10ga? wire that goes from the ignition switch to the thermostart glow plug in the intake manifold.
You will use that instead to power your coil.
The original gas harness has about a 5' resister wire that was folded into 3, wrapped with tape and powered the coil. Save that, connect it on the end of the 10 ga wire and re hook to your coil.
On the switch end of the 10 ga thermostart wire you will have to cut the big spade clip that plugs onto the back of the switch and replace it with a 'normal' size one.
EZ |
| Back to top |
Jetbird Regular
Posted: Sat Oct 06, 2012 2:48 pm Post subject: Re: Wiring harness |
Thanks for the help, guys. I know next to nothing about my wiring/ignition system. I am somewhat inclined just to buy the harness, since it seems cheap enough. I could probably use some help setting it up, though. Greg, I would definitely like to have you come out for that visit soon. I will have to check with my wife to find a good time. I think she may be getting a little tired of being a "tractor widow". I fired the tractor up for the first time since july today. I now have new ps pump, new ps lines, rebuilt steering box, new inner and outer axle oil seals, new brakes, new fuel pump, new exhaust header, new tach cable, new hydraulic filters, new cap, rotor, plugs. |
| Back to top |
Jetbird Regular
Posted: Mon Oct 08, 2012 6:23 pm Post subject: Re: Wiring harness |
OK, I don't know where my resistor wire is or what it looks like. If I am guessing right it goes from one of the low-voltage terminals on the coil then over to the ignition switch? I will have to check that out.
Take a look at this photo of my coil.
What is that little can that looks like a condenser doing connected to the coil and screwed to the coil mounting bracket? I ordered a new coil from my New Holland dealer (since the high tension connection on the top is broken) and I don't know if it will have that little "condenser" on it or if I need to reuse it... |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
