Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Late JD A vs. JD 60
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling
pullinman
PostPosted: Sat Oct 06, 2012 7:04 am    Post subject: Late JD A vs. JD 60 Reply to specific post Reply with quote
I was told that a late jd a motor is the same as a jd 60. cam..crank..block...head..etc?? Not real sure but would like to see if anyone had a good answer for me??
buickanddeere
PostPosted: Sat Oct 06, 2012 9:13 am    Post subject: Re: Late JD A vs. JD 60 Reply to specific post Reply with quote
Find your adviser and kick his stupid *ss. And don't take any more advice from him.
BushogPapa
PostPosted: Sat Oct 06, 2012 11:47 am    Post subject: Re: Late JD A vs. JD 60 Reply to specific post Reply with quote
Well..the Bore and Stroke are the same....and the very first All-Fuel 60's may have still had the single throat carburetor on them...
Ron..
2-banger
PostPosted: Sat Oct 06, 2012 12:32 pm    Post subject: Re: Late JD A vs. JD 60 Reply to specific post Reply with quote
same bore and stroke..pistons interchange..you csn put a 60 hd on a late a ..60 block will fit in an a but a block doesnt have holes on the bottom that go thru frame like 60
mark us
PostPosted: Sat Oct 06, 2012 4:51 pm    Post subject: Re: Late JD A vs. JD 60 Reply to specific post Reply with quote
can you be more specific there B&D
mm585
PostPosted: Sat Oct 06, 2012 6:13 pm    Post subject: Re: Late JD A vs. JD 60 Reply to specific post Reply with quote
I beleve what buickanddeere meant to say was no a late A and a 60 arent the same. Im not a deere guy but as i recall the 60 runs a duplex carb, and the block and pistons are shorter unless mabie you have an all fuel tractor,(mabie thats only on the 70) and the heads are a diffrent monkey also. I think the stroke is the same unless you have an unstyled A. Im sure if im wrong some one will corect me or atleast call me an idot!
buickanddeere
PostPosted: Sun Oct 07, 2012 8:44 am    Post subject: Re: Late JD A vs. JD 60 Reply to specific post Reply with quote
A and 60 had the same stroke but the 60's crank was updated for live pto.
All 60's used insert connecting rods. The A's were babbit.
The late 60's had a much high output generator.
The A and 60 heads all used the same bolt patten but the gasser 60, LP's and late all fuels after serial # 6013899 used duplex intake ports and carb.
The duplex engines made more power on less fuel.
The single barrel A's and the early all fuel 60. One cylinder ran too rich while the other cylinder ran too lean.
The 60's used a powered crankcase ventilator pump. A's didn't use a pump until serial # 692121.
The gasser A was 5.6 to 1 compression and used a 2-1/4" intake and 2-1/32 exhaust.
The gasser 60 compression was 6.08 to 1 and used 2-1/4" intakes and surprisingly only 1.900 exhaust valves.
Cam timing was identical on the A and 60.
The 60's used a much superior thermostat coolant temp control.
The styled A and the 60 cylinder blocks were for all intents and purposes identical.
For pulling it's easier to lighten the A into the 5500lb class than a 60.
The 60 is still makes a useful odd jobs tractor around any farm with live hydraulics,optional live pto and optional power steering.
There is even a Saginaw top link to give a 60 a real and complete three point hitch.
Kind of a shame to cut up a 60 into an all out puller.
Post new topic    Yesterday's Tractors Forum Index -> Tractor Pulling All times are GMT - 8 Hours
