| Author |
Message |
JOHN in PENNSYLVANIA Regular
Posted: Sat Oct 06, 2012 8:49 am Post subject: diesel tractor not running good UPDATE |
First of all thank you everyone for their input I really appreciate all the help. Here is the situation currently. It was actually a little hard to start this morning not like normal. I removed the air hose on the intake manifold so there's no restrictions it feels to be drawing in nicely. I remove the valve cover started the engine. All valves seem to be working fine moving freely and plenty of oil pumping. I cracked all the lines to each injector one at a time. The RPM dropped on every injector allowed to leak fuel. It seems too be idling smooth and up to 1200 RPM runs smooth. There's very little smoke at idle but when you open the throttle wide it's coal black. For anyone new looking at this post it's an international 364 diesel tractor. With a Bd 154 engine and a CAV injection pump. Only 1200 hours on the hour meter. |
| Back to top |
Posted: Sat Oct 06, 2012 8:50 am Post subject: Re: diesel tractor not running good UPDATE |
Forgot to mention I'm in the shop right now so if there is something you want me to check or try please let me know |
| Back to top |
CAROGATOR Long Time User
Posted: Sat Oct 06, 2012 9:27 am Post subject: Re: diesel tractor not running good UPDATE |
You moght want to check that your tank vent is open and not plugged. |
| Back to top |
JimB2 Long Time User
Posted: Sat Oct 06, 2012 9:35 am Post subject: Re: diesel tractor not running good UPDATE |
Hi John, run it up to where it is smoking badly and pull the shut off lever out a little and see if the smoke stops?
I have a Perkins Diesel engine trouble shooting guide and a DPA CAV rotary injection pump test instructions guide in pdf format.
If you email at clarabrownlee@rogers.com, I can email them to you.
JimB |
| Back to top |
oldtanker Tractor Guru
Posted: Sat Oct 06, 2012 9:41 am Post subject: Re: diesel tractor not running good UPDATE |
The black smoke indicates one of several things.
1. Air restriction giving a rich fuel air mixture.
2. Pump/injector problem, feeding too much fuel, making a rich fuel air mixture.
3. Engine problem giving a poor burn. Low compression, bad timing ECT.
So from what you have done so far, check valve clearances seeing as how the cover is off. Then check injector timing by the book. Check and make sure the fuel return line isn't plugged. That can cause the pump to make to much pressure and cause a rich fuel mix problem.
Once al of that is done if you still have a problem it amy be time to pull the pump and injectors and have them tested. Doing a compression test would be in order too.
Rick |
| Back to top |
Posted: Sat Oct 06, 2012 9:59 am Post subject: Re: diesel tractor not running good UPDATE |
When i rev it up....black smoke until it reaches its RPM. The the smoke is vert little. If i pull the shut off part way out i have no throttle response. I will email you....thanks |
| Back to top |
Posted: Sat Oct 06, 2012 10:00 am Post subject: Re: diesel tractor not running good UPDATE |
I will check the timing and valves |
| Back to top |
Posted: Sat Oct 06, 2012 10:08 am Post subject: Re: diesel tractor not running good UPDATE |
Tried to email you....did not go. My email is jwmirz@aol.com |
| Back to top |
Posted: Sat Oct 06, 2012 11:50 am Post subject: Re: diesel tractor not running good UPDATE |
Hi John,
I got delayed but emailed the two pdf docs to you about 20 minutes ago.
JimB |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
