| Author |
Message |
Clint Skarovsky Regular
Posted: Sat Oct 06, 2012 9:21 am Post subject: Someone please tell me I'm not the only one..... |
So I had a mixed bag last weekend. I got my 13 yr old to tractor pull for the first time on my recently purchased '51 JD A and he loved it. The bad - while the tractor was idling at the pull it dropped a valve. The results are almost the worst possible - broke the valve, damaged the guide, ruined the seat, broken valvespring and I've got a nasty little divot in the cylinder wall.
So I'm about to bore it .125", fix the head, and put it back together. I just bought the tractor for $1200 and now I'm going to spend $1200 on it to get it going again...........damn hot rodding. Someone please tell me that I'm normal. Thanks |
| Back to top |
Ray Tellin Regular
Posted: Sat Oct 06, 2012 11:27 am Post subject: Re: Someone please tell me I'm not the only one..... |
Welcome to pulling! |
| Back to top |
Posted: Sat Oct 06, 2012 11:35 am Post subject: Re: Someone please tell me I'm not the only one..... |
I know but it's the reason that I've been doing the antique pulling instead of drag racing - nothing is supposed to break if treated properly. Oh well, bigger, stronger, faster. |
| Back to top |
emtiv1099 Regular
Posted: Sat Oct 06, 2012 11:43 am Post subject: Re: Someone please tell me I'm not the only one..... |
That stuff happens but it's all apart of it. Just be glad you it didn't get the whole engine along with the head. |
| Back to top |
BenAlbert Regular
Posted: Sat Oct 06, 2012 2:17 pm Post subject: Re: Someone please tell me I'm not the only one..... |
Already bought my son a tractor, and he's only 7. Worst part is his sister is making like she wants one too. Thats gonna take another tractor, and a bigger truck and trailer. There's no way I'm just going to be pit crew and let them run mine! At least I have some time to worry about it. |
| Back to top |
north puller Long Time User
Posted: Sat Oct 06, 2012 2:41 pm Post subject: Re: Someone please tell me I'm not the only one..... |
That problem was going to surface no mater what you are doing. Its not your fault or pulling's fault.
Ever been plowing along at a good clip and hooked a boulder?
Ever stuffed a big waud in a silo blower or a snow blower and killed her dead?
Ever had a wagon overloaded push you down a hill and wind the motor up a little faster than it should?
Ever tried to show off and pull a plow to big or too fast and beat the sh!t out of your tractor.
Point is, farming can be and often is harder on a tractor than pulling.
I would say that if the motor is within 150% of factory horsepower, and within 120% of factory rpm, and all in good mechanical repair, you can pull all day long and not hurt anything.
Good luck and don't give up. |
| Back to top |
mark us Regular
Posted: Sat Oct 06, 2012 4:47 pm Post subject: Re: Someone please tell me I'm not the only one..... |
i think i detected your problem in the last part your fist sentence |
| Back to top |
mm585 Regular
Posted: Sat Oct 06, 2012 6:22 pm Post subject: Re: Someone please tell me I'm not the only one..... |
Thats tractor pulling!!!!Aint it great???Always remember golf clubs arent cheap eather, and they dont even make any noise!! |
| Back to top |
Posted: Sun Oct 07, 2012 8:11 am Post subject: Re: Someone please tell me I'm not the only one..... |
Thanks guys, I just needed to feel better....the bad thing is if it was my '45 A with a power block (which I over-rev regularly) I wouldn't have been that surprised and may have just parted out the tractor. This is my bone-stock puller for the kids...oh well, I'll keep everyone posted when I actually put it back together. I've got to pull the block in the coming days for its sleeve project. |
| Back to top |
mightymolinekid Regular
Posted: Sun Oct 07, 2012 1:47 pm Post subject: Re: Someone please tell me I'm not the only one..... |
Nope it happens. Last year I put together a brand new engine, got it broke in, hooked twice and took it to a dyno. There we seized it tight, scoring 2 pistons and spun the rear main bearing. I waited 10 months and had to raise the roof at the machine shop for a boat anchor. He tells me bring it back they messed up. Waited another 5 months got it this spring, put together, got it running only to find they installed the wrong front cam bushing. I lose oil to my front valves when it gets to temperature. Both times I got the engine back from them complete, all I had to do was proper torque on the heads and do the light assembly, valve train, etc. So....it happens....... |
| Back to top |
mm fan Regular
Posted: Mon Oct 08, 2012 3:53 am Post subject: Re: Someone please tell me I'm not the only one..... |
Clint,
I've got a power block that will go in that A, with the pistons. I can bring it to Cuero this weekend. My email's open |
| Back to top |
730-LP Long Time User
Posted: Mon Oct 08, 2012 4:32 am Post subject: Re: Someone please tell me I'm not the only one..... |
Bore it .0125 over and put a set of standard bore G pistons in it,with a good head it will make 60 HP.I have a new set of G pistons that has been machined for a power block,if you are interested my e-mail is open |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
