Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
3588 torque ?
Greg Hammel
PostPosted: Sat Oct 06, 2012 11:23 am    Post subject: 3588 torque ? Reply to specific post Reply with quote
Picked up a 3588 from a gentleman,said it needed a torque, weird thing to me is that the high side will slip but the low side seems to hold just fine.Dont you usually loose the low side? like high side is direct. Anyone have some insight on the problem? Thanks Greg
Allan in NE
PostPosted: Sat Oct 06, 2012 11:32 am    Post subject: Re: 3588 torque ? Reply to specific post Reply with quote
Makes a guy wonder 'bout the clutch, doesn't it....
Allan
Janicholson
PostPosted: Sat Oct 06, 2012 12:06 pm    Post subject: Re: 3588 torque ? Reply to specific post Reply with quote
If the tractor operates as follows, it has a front or direct TA clutch that is weak, or has a failed hydraulic piston seal, or seals in the supply pathways to the piston.
When in direct, the tractor will operate pretty well normally in lower gears when lightly loaded, or coasting. When a load is applied (such as lowering a disk into soil, the tractor will go into the governor a little, then start to slow down to the speed of the TA reduction. if the TA is pulled back, the tractor will continue at that speed.
If this is not the case, if the tractor continues to go slower, than TA back, then it likely has a weak master clutch. if not other issues. Jim
Greg Hammel
PostPosted: Sat Oct 06, 2012 12:23 pm    Post subject: Re: 3588 torque ? Reply to specific post Reply with quote
That is exactly what happens it will slip back to TA reduction speed. What would your first step of diagnosis be? check pressures? Split, tear apart? Thanks again
scotc
PostPosted: Sat Oct 06, 2012 1:38 pm    Post subject: Re: 3588 torque ? Reply to specific post Reply with quote
Do like we did- leave the lever back and run it.
Janicholson
PostPosted: Sat Oct 06, 2012 1:55 pm    Post subject: Re: 3588 torque ? Reply to specific post Reply with quote
The control pressure comes from the MCV pump and control is determined by valving. The pump pressure is multi-function and not limited to the TA clutch. Brakes, Steering, and Trans lube are dependent on that pressure. If the TA direct clutch is deteriorating it can contaminate many other components. Living with it is not good.
If the pressure from the TA control is also weak at the lockup clutch (rear clutch) the tractor can both toast that clutch, and runaway down hill. (with possibly less than 100% brakes. !!!!
I believe in TA equipped tractors. They are very much a factor making the tractors desirable, and work horses. My opinion is fix it. Jim
mkirsch
PostPosted: Sat Oct 06, 2012 2:14 pm    Post subject: Re: 3588 torque ? Reply to specific post Reply with quote
A mechanical TA will usually go out on the low side first.
The 3588 has a hydraulic TA. On those, it's anyone's guess which side will go out.
With a mechanical TA you can run indefinitely on the high side. Once one side of a hydraulic TA goes out, the other side is not far behind.
the tractor vet
PostPosted: Sat Oct 06, 2012 2:49 pm    Post subject: Re: 3588 torque ? Reply to specific post Reply with quote
Put the gauges to it and see where your at on lock up pressure. Then also load it down in a higher gear on the low side and see if ya have slippage . Until i had some presure readings and check and see if the T/A control is working correctly and adjusted . Myself i would be leaning to the main clutch . But we are all just guessing as myself i can not test and see.
pete 23
PostPosted: Sat Oct 06, 2012 6:27 pm    Post subject: Re: 3588 torque ? Reply to specific post Reply with quote
A 2+2 has a little different path for the oil through the mcv than the row crop tractors. The flow divider does not control the flow to the steering as it does in other models. I have seen a couple of them where the pressure regulator valve and or flow divider sticks from contamination from the steering pump. I put a lot of filter screens fittings in to help solve this problem. Originally they did not have one. At any rate, the steering may still be working fine and you lose oil to the TA and brakes etc so direct drive will slip or not work at all. Check your regulated pressures and go from there. The red light should be giving you indications but so many tractors have red lights that don't work for various reasons and when you are new to a tractor you may not realize how it is supposed to work.
