Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
saginaw hitch review
Post new topic    Yesterday's Tractors Forum Index -> John Deere
sgtbull
PostPosted: Sat Oct 06, 2012 2:26 pm    Post subject: saginaw hitch review Reply to specific post Reply with quote
Just bought my new Saginaw hitch for my JD 70. Here's my observations:
Cost was $700 delivered to my friendly local JD dealer. (business delivery is less expensive than home delivery.)
The Hitch was fully assembled, wired to a pallet. It loaded easily in the back of my truck.
The hitch came complete with all pins and necessary hardware EXCEPT bolts to attach it to the axle housing itself. It was explained that many use the studs normally found in the axle housing, which I did too. 4 large flatwashers are included, however.
I found that it was easiest to disassemble the hitch on the pallet, and reassemble it as I installed it. By doing so, one person can easily handle any portion of it. Its best to put the two bottom supports on first, then the top link bracket, followed by the lift arm assemblies. I had the entire thing off the pallet, installed on the tractor and operational in 45 minutes.
The only bad things were that neither the original PTO shield or flpper shield can be used with this hitch as there isn't enough clearance. The hydraulic outlets are still accessible however, an it appears there is adequate room for a pto shaft to be attached easily. Additionally, the pin holes were pretty tight, requiring a hammer to remove them. A few seconds with a air grinder and burr bit removed the burrs inside the holes alleviateding the problem and makeing the pins go in easily. Part of the problem was the upc stickers on the new pins.
The lift arms attach easily to the rockshaft, requiring only a bit of assistance by a rubber mallet, to get past the paint. Two 15/16" wrenches and two 3/4" wrenches were all that was needed to install everthing.
The hitch came with a new toplink and was ready to use immediately after installation. I like the fact that the lift arms can be quickly and easily adjusted, but they do require a large wrench to loosen or tighten the jam nuts.
The anti sway bars are easily adjusted by use of a set screw set up and could be removed entirely in seconds.
I'll report back on actual use after we get some dry weather and I get a chance to do some mowing.
sgtbull
PostPosted: Sat Oct 06, 2012 2:29 pm    Post subject: Re: saginaw hitch review Reply to specific post Reply with quote
One thing I forgot to add was that the gentleman I spoke with on the phone was very helpful. I had some questions about measurements and he didn't hesitate to assist me, even taking measurements on the hitch he sells for my reference. I ordered the hitch and it was in my shop in less than 48 hrs.
Dalet
PostPosted: Sun Oct 07, 2012 7:53 am    Post subject: Re: saginaw hitch review Reply to specific post Reply with quote
Wow that looks nice! I may have to spring for one for the 520, that would make it a pretty handy tractor.
CLW
PostPosted: Sun Oct 07, 2012 8:21 am    Post subject: Re: saginaw hitch review Reply to specific post Reply with quote
I have heard if you want an aftermarket 3-point to USE it is far and away the best one out there. Keep us posted.
CLW
Double posted, Embarassed
CLW
PostPosted: Sun Oct 07, 2012 8:22 am    Post subject: Re: saginaw hitch review Reply to specific post Reply with quote
Triple posted, Sad
