Another clutch problem
BigTone
PostPosted: Sat Oct 06, 2012 2:49 pm    Post subject: Another clutch problem Reply to specific post Reply with quote
Went to adjust the clutch and the Nut wont move. Hit it with pb blaster for hours and nothing. I measured the free play from the transmission deck to the point that the pedal engages the bearing and its close to 2" of free play, the book says 1 1/8". The bearing is about a 1/4" away from the clutch fingers when the pedal is against the transmission deck and i was told it should be 1/8th.
Should I be looking for a new clutch rod? I might be able to get the nut loose with heat and a few days of pb blaster but im afraid the rod wont screw into the bracket. Any ideas? ~Thanks, Anthony
BigTone
PostPosted: Sat Oct 06, 2012 2:56 pm    Post subject: Re: Another clutch problem Reply to specific post Reply with quote
It might be 3" of free play, I guess I measured to the front of the pedal and im supposed to measure from the transmission deck to the back surface of the pedal arm? I Dont know !!
kevinj54
PostPosted: Sat Oct 06, 2012 3:16 pm    Post subject: Re: Another clutch problem Reply to specific post Reply with quote
Take the rod off and heat it a bit.
kevinj54
PostPosted: Sat Oct 06, 2012 3:18 pm    Post subject: Re: Another clutch problem Reply to specific post Reply with quote
BigTone wrote:
(quoted from post at 19:56:34 10/06/12) It might be 3" of free play, I guess I measured to the front of the pedal and im supposed to measure from the transmission deck to the back surface of the pedal arm? I Dont know !!
Do you not have a manual for this thing????? If not you should get one as all of the maintenance type stuff is in there.
BigTone
PostPosted: Sat Oct 06, 2012 3:23 pm    Post subject: Re: Another clutch problem Reply to specific post Reply with quote
yeah, I have ALL the manuels for the M, service/operators/blue ribbon/parts catalog but all it says is to adjust the free play, not HOW to do it, or WHERE to measure from and to. They are not written for someone who has NEVER done it before and let me tell you its very frustrating!!!
Janicholson
PostPosted: Sat Oct 06, 2012 3:26 pm    Post subject: Re: Another clutch problem Reply to specific post Reply with quote
The measurement is between, not to the front side.
Take the pins out of the rod, and put it in a vise.
Heat the material as needed to free it. It will adjust. Jim
kevinj54
PostPosted: Sun Oct 07, 2012 11:31 am    Post subject: Re: Another clutch problem Reply to specific post Reply with quote
BigTone wrote:
(quoted from post at 20:23:10 10/06/12) yeah, I have ALL the manuels for the M, service/operators/blue ribbon/parts catalog but all it says is to adjust the free play, not HOW to do it, or WHERE to measure from and to. They are not written for someone who has NEVER done it before and let me tell you its very frustrating!!!
In my ops book it is on PAGE 60.
"It is important that a clearance of 3/16" be maintained between the clutch release bearing and the clutch release levers"
"In order to maintain clearance the clutch pedal free play should be 1-1/8", measurement to be taken between the point of contact of the clutch pedal arm with the rear frame cover when clutch is fully engaged"
"the correct free movement can be maintained by adjusting the length of the clutch operating rod between the clutch pedal and the release shaft lever"
Hope this helps.
MisterT
PostPosted: Sun Oct 07, 2012 12:17 pm    Post subject: Re: Another clutch problem Reply to specific post Reply with quote
Janicholson wrote:
(quoted from post at 00:26:36 10/07/12) The measurement is between, not to the front side.
An oxy/acetylene torch is a "must have" if you're going to be working on these old tractors.
kevinj54
PostPosted: Sun Oct 07, 2012 12:25 pm    Post subject: Re: Another clutch problem Reply to specific post Reply with quote
That is a fact Exclamation I could not get by without torches, welders, and a shop full of tools.
After 40 years of making a living in the repair field I have accumulated a fair set of tools. Cool
