Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
positive to negitive ground
hrtuffenuff
PostPosted: Sat Oct 06, 2012 5:31 pm    Post subject: positive to negitive ground Reply to specific post Reply with quote
can i change a 12 volt positive ground system to negitive ground by changing voltage regulator.
Or does gen. need to be changed internally?
gene bender
PostPosted: Sat Oct 06, 2012 5:35 pm    Post subject: Re: positive to negitive ground Reply to specific post Reply with quote
polarize the gen
Nebraska Kirk
PostPosted: Sat Oct 06, 2012 5:38 pm    Post subject: Re: positive to negitive ground Reply to specific post Reply with quote
You do not need to change anything in the generator, but after changing to negative ground, you will need to repolarize the generator.
pete 23
PostPosted: Sat Oct 06, 2012 5:44 pm    Post subject: Re: positive to negitive ground Reply to specific post Reply with quote
A generator does not care which way it is grounded, neg or pos. Some voltage regulators do but most you buy now days work with either ground. Ordinarily a regulator is marked if it is polarity sensitive, on the under side or on mount somewhere saying which ground it is. At any rate, you need to polarize it to the ground system you are using. Momentarily , with everything hooked up but before you start engine, flash the generator terminal to the battery terminal. Just use any kind of a jumper wire to touch them terminals so you get a spark and that will turn those little electrons so their north and south poles are pointing in the right direction.
wisbaker
PostPosted: Sat Oct 06, 2012 6:52 pm    Post subject: Re: positive to negitive ground Reply to specific post Reply with quote
If it's a gasser (spark ignition) you should also change the coil polarity & the leads on the ammeter.
mkirsch
PostPosted: Sun Oct 07, 2012 6:27 am    Post subject: Re: positive to negitive ground Reply to specific post Reply with quote
On a generator/regulator setup, you only need to do three things to swap ground:
1. Switch the cables on the battery.
2. Switch the cables on the ammeter.
3. Polarize the generator.
Please note you can NOT do this to an alternator system.
John T
PostPosted: Sun Oct 07, 2012 7:26 am    Post subject: Re: positive to negitive ground Reply to specific post Reply with quote
As noted and first of all, the genny can charge at either Pos or Neg Ground and of course, you need to Polarize the genny BEFORE start up. Some VR's are labeled as suitable for use at Pos or Neg ground, so you might wanna check that. If its a batery powered coil distributor ignition and you change battery polarity the coil leads need swapped also as well as the ammeter leads (if it has one) or it would read bass ackwards.
John T
