| Author |
Message |
RalphWD45 Long Time User
Posted: Sat Oct 06, 2012 8:06 pm Post subject: adding fescue to pasture ? |
I have had 3 kinds of clover, along with preanial rye grass, orchard grass, some timothy, and of course the native cheat grass, in my 8 acres of pasture. The summer drought came along, and in spite of feeding hay early, the cows turned the pasture into a brown golfcourse. No other place to put the cows, other than in the yard. The fescue, that is in the chicken yard, held up real well, and stayed green, all the way thru the dry spell, which ain't over yet. If I sow fescue over the existing grasses, will the cows eat it? Will the fescue crowd out the other grasses, and clover?, or will I end up with a drought proof green pasture that is no good to me? That is if the rains ever come, and I can salvage some of the existing roots! |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50459 Location: Lake of the Ozarks area of MO
Posted: Sat Oct 06, 2012 8:17 pm Post subject: Re: adding fescue to pasture ? |
You can not pay me to plant fescue no matter what. It is a grass few want as hay and can take over a field in just a few years. I have been fighting it for 30 plus years and slowly I have it down to maybe 20% of my pasture but even then few want it in hay if they know you have it. |
| Back to top |
Gordon in IN Regular
Posted: Sat Oct 06, 2012 9:03 pm Post subject: Re: adding fescue to pasture ? |
Only plant fescue if you do not want anything else in the field.
It is great for "along highways" and "rough yards" , but not much else. Just my opinion. |
| Back to top |
johndeeregene Regular
Posted: Sat Oct 06, 2012 9:07 pm Post subject: Re: adding fescue to pasture ? |
dont do it, planted it one time here on the place, cattle will not eat it if it starts to get taller an is hard on preg cows raises their body temp, was told by the vet.
trying to get rid of it here.
johndeeregene |
| Back to top |
JDseller Tractor Guru
Joined: 09 Jul 2010 Posts: 4483 Location: North-East Iowa
Posted: Sat Oct 06, 2012 9:13 pm Post subject: Re: adding fescue to pasture ? |
Fescue is a low quality forage. So even if you have a lot of it it will not have the nutrient valve of the other forages. Plus there are problems with a fungus that grow in fescue.
" An endophyte is a plant which grows within another plant, in this case a fungus growing within the fescue plant. This fungus, acremonium coenophialum, has been shown to be associated with the occurrence of alkaloids in this species. These alkaloids are toxins that relate to summer slump syndrome and fescue toxicosis. Research has shown that cattle birth weights and weaning weights will be effected negatively with infected fescue hay."
Then to add insult to injury the fescue will choke out the better forages. So I would never knowing sow it for a pasture. Your problem this summer was lack of water not choice of forages. We do not have that happen that often. So I would rather have good forages most of the time with the occasional bad time rather than have poor forages all of the time. |
| Back to top |
mo -U puller Guest
Posted: Sat Oct 06, 2012 10:00 pm Post subject: Re: adding fescue to pasture ? |
Fescue is the main reason Mo. is 2nd beef producing state in the US and Polk county is no. 1 beef county in Mo. Don"t listen to this BS. Nuff said. |
| Back to top |
Deere Scotty Long Time User
Posted: Sat Oct 06, 2012 10:03 pm Post subject: Re: adding fescue to pasture ? |
I'd try Alfalfa maybe; but Fescue... no thank you. Alfalfa's roots go deep in the soil. |
| Back to top |
led Regular
Posted: Sun Oct 07, 2012 12:50 am Post subject: Re: adding fescue to pasture ? |
My dad used to say "Takes a good fence to make a cow eat fescue".
Led |
| Back to top |
Dachshund Regular
Posted: Sun Oct 07, 2012 3:52 am Post subject: Re: adding fescue to pasture ? |
There is endophyte free fescue..... |
| Back to top |
Wheat Farmer Long Time User
Posted: Sun Oct 07, 2012 4:43 am Post subject: Re: adding fescue to pasture ? |
We DO NOT want Fescue in our hay that we feed Alpacas. NorthWest US is known for High levels of Fescue. Lawn grass is know for high levels of fescue we do not let animals graze it, nor put clippings in the compost piles. |
| Back to top |
thurlow Tractor Guru
Posted: Sun Oct 07, 2012 4:55 am Post subject: Re: adding fescue to pasture ? |
In my part of the country, fescus is THE base pasture grass for beef cattle; everything else is just an 'add-on' and requires considerable management to keep it alive. Fescue is still here when everything else has dried up (it will) and died. |
| Back to top |
Posted: Sun Oct 07, 2012 6:31 am Post subject: Re: adding fescue to pasture ? |
Well you have several FACTS wrong here. Missouri may be the second calf producing state but it is not in the top five in total cattle. The reason Missouri has so many brood cows is that much of the state is just fit for pasture. Thats is just how the states land lays. IF that same pasture had some other grass than fescue than you would get even more beef per acre. Been proven in many feed trials. Plus the fescus will cause fertility problems in dry times.
TEN LARGEST STATES--2008
Number Head (in millions) % of U.S.
1. Texas ----------13.8------- 14.3%
2. Kansas ---------6.7 --------6.9
3. Nebraska ------6.6 --------6.8
4. California ------5.5 --------5.6
5. Oklahoma -----5.4 --------5.6
6. Missouri -------4.3 --------4.5
7. Iowa -----------4.0 --------4.1
8. South Dakota 3.7 --------3.8
9. Wisconsin -----3.4 --------3.5
10. Colorado -----2.8-------- 2.8 |
| Back to top |
George Marsh Tractor Expert
Joined: 05 Aug 2009 Posts: 3006 Location: terre haute
Posted: Sun Oct 07, 2012 6:40 am Post subject: Re: adding fescue to pasture ? |
Ralph,
I too found that red creaping fescue survived in my gravel pit, sand and gravel and no rain. Went to Rural King to buy grass seed for yard. They had a blend of ky blue grass, red fescue, perniall rye and annual rye, about 25% of each, $40 for 25#. They also have a 50# bag of tall fescue for $44.
Oct 4 they had a 15% off rebate and I bought 175# of the blend and 50# of tall fescue. Plan to snow seed about an acre of yard some time in December. Got the ground disked up. Going to wait and disk again.
Google fescue, some say it has little value as a food source, but it will grow in very poor conditions.
I don't plan to feed anything, I just want a nice looking yard if we go throught another dry summer.
George |
| Back to top |
jackinok Tractor Expert
Posted: Sun Oct 07, 2012 7:07 am Post subject: Re: adding fescue to pasture ? |
ive run a lot of cattle on fescue,but it does have a few problems.first while it survives drought well once established,it take a lot of water to get established around here.mostly its grown in the eastern side of the state with way more rainfall. second and sometimes a real problem ,it crowds out native grasses alot of times.third and why a lot of folks dont like it,it has a tendency to lay down and form a dense thatch.youve got to either graze it pretty well off,or go in and work it with a cultivator or something every three or four years to keep it upright and growing. if your cutting a placefor hay two or three times a year it does ok,and you can stretch your reworking times way out. IN MY experience with it,cattle will eat all the native grasses or clovers out first,so you eventually lose them.Like i say ive used lot of it and for a time it was my main hay crop,but it does have problems.one MAJOR thing i didnt like was very few wildlife spiecies use it,quail and ground nesting birds wont use it,simply because they cant move through it.same with rabbits .folks have told me its toxic to deer,but i cant verify that,but i do know i dont see them on it much other than passing through. it does however if left to thatch make a perfect place for rats and rodents,so dont plant it close to your house or barns,unless you can maintain it.MY opinion of course. |
| Back to top |
old Tractor Guru
Posted: Sun Oct 07, 2012 8:04 am Post subject: Re: adding fescue to pasture ? |
One word for you. WRONG!!!!!!!!!!!!!!!!! Missouri has poor ground in most of it so fescue is one of the few things that will grow in the rock and clay we have. Fescue is known to cause many problems with cows producing milk and also known to cause grass tetna (sp) Been fighting the stuff for 32 years and have slowly got my pasture down to less then 50% fescue |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
