| Author |
Message |
scott-in-mich Guest
Posted: Sun Oct 07, 2012 6:25 am Post subject: 231 massey |
Gentlemen, I'm a farmall guy, but looking to trade a couple of them for a 231 massey. Any help you can give,I'd be thankful for. Is it a good,sound tractor? Will be using it mostly for snow plowing and brush hogging. It has a Perkins 3cyl. diesel, 807 hrs. on it. It's a 19996 model. What's the difference between a 231 and a 231s? As always, thanks for any and all replys. Scott. |
| Back to top |
Gearhead210 Regular
Posted: Sun Oct 07, 2012 6:52 am Post subject: Re: 231 massey |
That is a sweet little tractor, the 3 cyl diesels are a bulletproof powerhouse. I don't know the difference between of the "S" model, but with one that has that low of hours on it it would be a great tractor |
| Back to top |
TonyW.I. New User
Posted: Sun Oct 07, 2012 7:06 am Post subject: Re: 231 massey |
We have a 231 we bought brand new. Had a bearing fail in rear end at 400hrs, other than that its been pretty a pretty durable tractor. We use it a lot with bush hog mower and is really handy in cow yard with a blade, nice with 2 bottom plow in gardens and food plots also. I would suggest putting a brush guard in front of radiator for brush work. We had a stick go thru the grill into the radiator and had to wait for a month for a new radiator to come from europe. Also it has a road speed of like 24 mph! |
| Back to top |
231 MF Guest
Posted: Sun Oct 07, 2012 8:09 am Post subject: Re: 231 massey |
A 231 is a good tractor. I think the S model is made in another country like Turkey or something like that. 807 hours isn't even broken in yet on the engine. Very fuel efficient too. |
| Back to top |
curtis larson Regular
Posted: Sun Oct 07, 2012 9:47 am Post subject: Re: 231 massey |
The 231 was built in Poland. The 231S Had Swing clutch and brake peddles.They were just the next model. |
| Back to top |
FBH44 Long Time User
Posted: Mon Oct 08, 2012 3:32 am Post subject: Re: 231 massey |
I have a 240-S, made in Turkey. Near as can be told, it is identical to the 240. Just made by Uzel, Turkey. The Perkins engine sips fuel, is very powerful. Great tractors. Parts easy to get from Agco dealers. |
| Back to top |
Dean Tractor Guru
Posted: Mon Oct 08, 2012 7:57 am Post subject: Re: 231 massey |
The 231 is the late 1980s/early 1990s version of the 135, which is a highly regarded small utility tractor.
The Perkins diesel versions are the most common and most desireable.
A couple of issues to be aware of: Dry drum brakes and fully UN-synchronized, sliding-gear transmission.
I have a 2007 533, which is the 2007 version. Aside from a few upgrades, 50 more cubic inches and a few more HP, it is much the same. It's been a good mowing work horse aside from a broken lower lift pin at 245 hours, which AGCO refused to repair under warranty, due to elapsed time, and a few other incidentals.
Note: You will need chains for MI snow removal.
Dean |
| Back to top |
495man Long Time User
Joined: 12 Jun 2007 Posts: 1053 Location: Nova Scotia, Canada
Posted: Mon Oct 08, 2012 4:33 pm Post subject: Re: 231 massey |
| Dean wrote: | (quoted from post at 08:57:40 10/08/12) T
Dean |
Agree. Have a 240 here, the drum brakes either work great or not great, no real in between.
Double clutch between speeds in high range and be completely stopped going F-R or between speeds low range and you can cope with the gear box. I do find Low R fine for snow blower, but wish for a slower High R gear.
I hang a snow blower on the back of the 240. I don't run chains, however I could sure use them at times, especially blowing uphill. |
| Back to top |
Tom in VA Regular
Posted: Tue Oct 09, 2012 3:26 am Post subject: Re: 231 massey |
Scott,
I purchased my 231 in 1999 because it was a lot of bang for the buck when compared to other tractors on the market at that time. Not as many refinements as the compact tractors of similar age but a lot more tractor for the money. It is used for mostly property maintenance now, bush hogging, mowing, tilling and some sickle bar mowing. I have also done a fair amount of grading with it.
I love it and it’s been a reliable tractor. I’d buy another one without hesitation. The Perkins engine starts easy and runs well. Plenty of power, it easily handles the 6’ tiller in heavy sod. The power steering turns easier than a car.
Only one cautionary note, if you are planning to put a loader on it, you will need the auxiliary hydraulic pump. The pumps are kind of pricey which might make you consider buying a tractor that already has a loader and sufficient hydraulic capacity. Other than that I wouldn’t hesitate to purchase a well maintained 231. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
