| Author |
Message |
Bob Keefer Guest
Posted: Sun Oct 07, 2012 6:49 am Post subject: rear wheel removal |
1940 9N Any suggestions on how to get the rear wheel off, think it is rusted on. Lug nuts are off and have been spring with masterblaster for last two days with no luck |
| Back to top |
Tom N MS Tractor Guru
Posted: Sun Oct 07, 2012 6:57 am Post subject: Re: rear wheel removal |
Start lug nuts back on all studs then get out and do all kinds of figure 8 manuevers. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50459 Location: Lake of the Ozarks area of MO
Posted: Sun Oct 07, 2012 8:21 am Post subject: Re: rear wheel removal |
As Tom says put them back on a little lose and take it for a drive and watch for it to pop loose so you do not mess up the treads on the bolts/lugs |
| Back to top |
bob keefer Guest
Posted: Sun Oct 07, 2012 12:36 pm Post subject: Re: rear wheel removal |
the tractor will not run |
| Back to top |
ray hofstetter Long Time User
Posted: Sun Oct 07, 2012 1:31 pm Post subject: Re: rear wheel removal |
Okay, I'LL ask what we're ALL thinking, why you want to take the wheel off if it don't run? |
| Back to top |
NoNewParts Long Time User
Posted: Sun Oct 07, 2012 1:42 pm Post subject: Re: rear wheel removal |
big chisel, big hammer from the back side.
close to the drum, turn the wheel to work your way around.
It'll come off.
(put a couple of lugnuts on so when it breaks loose, it doesn't fall) |
| Back to top |
old Tractor Guru
Posted: Sun Oct 07, 2012 2:48 pm Post subject: Re: rear wheel removal |
Well then have some one pull it around some in a ruff field or some such place and it will do the same thing as driving it would |
| Back to top |
old-9 Long Time User
Posted: Sun Oct 07, 2012 3:05 pm Post subject: Re: rear wheel removal |
What ever you do, DO NOT use a torch to heat it up. The sound didn't work but you get the point!!
Untitled URL Link
| Back to top |
HCooke Tractor Expert
Posted: Sun Oct 07, 2012 5:58 pm Post subject: Re: rear wheel removal |
Remove the fender. Use a big hammer on the inside edge of the rim. |
| Back to top |
Royse Tractor Expert
Posted: Sun Oct 07, 2012 6:38 pm Post subject: Re: rear wheel removal |
| Bob Keefer wrote: | | (quoted from post at 10:49:48 10/07/12) 1940 9N Any suggestions on how to get the rear wheel off, think it is rusted on. Lug nuts are off and have been spring with masterblaster for last two days with no luck |
If the tire will hold air, swing a maul and smack the tire.
Front or back or both, all the way around.
If it won't hold air, and the other suggestions don't work, take the six bolts
out of the outer rim and take the outer rim and tire off.
Maybe that's all you'll need to change the tire, but once that's off you could carefully apply heat.
If you do use heat, keep in mind where your seals, bearings and brakes are located.
I keep a fire extinguisher handy in case of a grease fire, but it would be
useless if you caught something on fire internally. |
| Back to top |
heybusdriver Long Time User
Joined: 25 Nov 2000 Posts: 817 Location: Surrey B.C. Canada
Posted: Sun Oct 07, 2012 8:39 pm Post subject: Re: rear wheel removal |
I've had them do the same thing, I just jacked it up and pounded the tire with a sledge hammer,front a few hits then back a few hits. Don't jack it in the middle just under the rear axle and only high enough so the wheel clears the ground.
Stan
2N with 8N motor 8N345567
8N 146710
8N 179555
8N 197904
8N 199000
8N 254079
8N 362039 |
| Back to top |
souNdguy Tractor Guru
Posted: Mon Oct 08, 2012 5:30 am Post subject: Re: rear wheel removal |
ditto what old said.. loose lugniuts and drag it a bit.
otherwise.. put an air hammer on it.. than and a board and sledge o matic a couple times.
when you put her back on.. grease the underside of the contact surface with neverseize. save the next guy the hassle.. you might be the next guy!  |
| Back to top |
1951 8N Regular
Posted: Mon Oct 08, 2012 10:34 am Post subject: Re: rear wheel removal |
| ray hofstetter wrote: | | Okay, I'LL ask what we're ALL thinking, why you want to take the wheel off if it don't run? |
SORRY, but that's not what we're all thinking. ONLY you are thinking this! |
| Back to top |
bob keefer Guest
Posted: Sun Oct 14, 2012 10:07 am Post subject: Re: rear wheel removal |
The wheel came off today after week of masterblaster,brake fuild.Was almost to easy. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
