| Author |
Message |
Deerepower53 Guest
Posted: Sun Oct 07, 2012 7:37 am Post subject: Flywheel |
Put a new taper loc flywheel on my john deere 70 and ran it at the house with no problems.Went to the pull got it off the trailer and the fly wheel came loss. Has anyone had trouble keeping these fly wheels tight and if so how did you fix the problem? Thanks |
| Back to top |
WI Walkin Boss Regular
Posted: Sun Oct 07, 2012 8:35 am Post subject: Re: Flywheel |
lock washers and permanent strength locktite |
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23708 Location: in front of computer
Posted: Sun Oct 07, 2012 8:47 am Post subject: Re: Flywheel |
Did you install the taper-loc as per the directions?
Never heard tell of a taper-loc coming loose when properly installed. In fact they are a real chore to remove as they get stuck on so tight.
If you just tightened the large jam nut once then drove away. Then yes the taper-loc will come loose. |
| Back to top |
Deerepower53 Guest
Posted: Sun Oct 07, 2012 9:01 am Post subject: Re: Flywheel |
It came with directions and I read them and done as it said. Maybe its my luck. |
| Back to top |
Posted: Sun Oct 07, 2012 9:45 am Post subject: Re: Flywheel |
Ok tell us exactly what you did to install the taper-loc. |
| Back to top |
Deerepower53 Guest
Posted: Sun Oct 07, 2012 10:51 am Post subject: Re: Flywheel |
I cleaned the crank of oil and put the taper loc on and got my end play right then put the fly wheel on put the nut on. Then started bumping it with the sledge hammer then tighting it over and over. |
| Back to top |
Posted: Sun Oct 07, 2012 11:14 am Post subject: Re: Flywheel |
Hmmmmmm.......Will have to bump and tighen it more.
How many lb ft of torque on the nut? |
| Back to top |
Deerepower53 Guest
Posted: Sun Oct 07, 2012 11:29 am Post subject: Re: Flywheel |
I took the fly wheel off and I'm going to start again. Not sure the lbs I used a big pipe wrench to tighten it. |
| Back to top |
Rwolfejr Regular
Joined: 19 Feb 2008 Posts: 233 Location: Western Pennsylvania
Posted: Mon Oct 08, 2012 7:13 am Post subject: Re: Flywheel |
| Deerepower53 wrote: | | (quoted from post at 20:29:57 10/07/12) I took the fly wheel off and I'm going to start again. Not sure the lbs I used a big pipe wrench to tighten it. |
Something that might help you with this...
If the instructions tell you how much to tighten the nut to in ft/lbs. you can easily get close to proper torque without a torque wrench on the larger stuff. Take your pipe wrench and stick a piece of tube over the handle for a cheater bar.
Then let's suppose they tell you that the nut needs to be tightened to 300 ft./lbs. and lets's say you weigh 200 lbs? When you tighten the thing up you want to grab the cheater bar at 1-1/2 feet from the centerline of the nut and hang your 200 lb. self off the bar and you'll have 300 ft.lbs. of torque give or take... on your nut. Or take a 100 lb. wheel weight and hang it 3 foot from the nut center = 300 foot pounds. Or 50 pound weight 6 foot out on your cheater bar = 300 ft./lbs.
Foot pounds of Torque = how much weight multiplied by how many feet out.
If you don't have any burrs or boogers on the crank and put it on clean and torque to what it's suppose to be you'll be good.
Good Luck!
Bob |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
