| Author |
Message |
internaltional 606 Guest
Posted: Sun Oct 07, 2012 1:43 pm Post subject: 44 john deere A |
I was wanting to know if a 44 A has a commom oil resivior with the transmision and engine like the early D's. What is the best way to tell if there is water in the oil. Where are the check holes for the engine oil and tranny oil. Kinda new to the green ones. usually ness around with the red ones but want something with a hand clutch for the kids. Give me the short education on Styled A's
Thank you |
| Back to top |
Badger bob Long Time User
Posted: Sun Oct 07, 2012 3:03 pm Post subject: Re: 44 john deere A |
no, engine has its oil and the trany has its oil (80W90) remove the oil plug for the engine and see if it leaks water. if it dont and the oil is not gray theres not water in it. but these tractors are good for sweating moister in to the cases. good luck . Bob |
| Back to top |
Greenday Long Time User
Joined: 08 Jun 2008 Posts: 1402 Location: NW Missouri
Posted: Mon Oct 08, 2012 3:38 am Post subject: Re: 44 john deere A |
Sounds like a ownwers manual would come in handy |
| Back to top |
James Howell Tractor Guru
Joined: 06 Mar 2006 Posts: 5623 Location: Hutchins, TX
Posted: Mon Oct 08, 2012 3:29 pm Post subject: Re: 44 john deere A |
Best way to check for water in the oil is to remove the crankcase drain plug.
The engine oil is checked at the oil level test cock on the right side of the tractor under the pulley.
Open and fill until it drips.
The transmission oil is checked at the fill plug.
Fill to the bottom of the threads.
Hope this helps. |
| Back to top |
Mike(NEOhio) Guest
Posted: Mon Oct 08, 2012 3:44 pm Post subject: Re: 44 john deere A |
While you're checking for water don't forget the small plug at the bottom of the reduction gear. I think it takes about a pint of engine oil in the smaller plug on top of the housing. I check mine every year or two and always get some water out of it.
Unless the '44s didn't have the plug, mine's a '51 |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
