Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Farmall M Hydraulic Pump out put shaft seal
Peter Hendrickson
PostPosted: Sun Oct 07, 2012 4:12 pm    Post subject: Farmall M Hydraulic Pump out put shaft seal Reply to specific post Reply with quote
anyone tell me how to get the coupler off that hooks to the hydraulic pump in the belly of the M so that I can get the seal out of the housing that is leaking? tried a small gear puller and the thing wont budge.
Thanks in Advance
jim warehime
PostPosted: Sun Oct 07, 2012 4:21 pm    Post subject: Re: Farmall M Hydraulic Pump out put shaft seal Reply to specific post Reply with quote
The drive hub is threaded on not pressed, try using a peice of 1/2 inch square stock or something that size and backing it off. Has worked for me might not hurt to put some heat on it first. Don't worry my first time trying to get one off I used a puller too lol. Jim.
Peter Hendrickson
PostPosted: Sun Oct 07, 2012 4:35 pm    Post subject: Re: Farmall M Hydraulic Pump out put shaft seal Reply to specific post Reply with quote
Is the one that threads on the one that comes out of the transmission with the slot in it?
I am a moline guy, putting a clutch in for my kids
jim warehime
PostPosted: Sun Oct 07, 2012 4:41 pm    Post subject: Re: Farmall M Hydraulic Pump out put shaft seal Reply to specific post Reply with quote
Yes both the drive coupler at the transmission housing (counter shaft) and the coupler on the belly pump are both threaded on. The main shaft which is on top is easy to swap out that seal. Jim
Peter Hendrickson
PostPosted: Sun Oct 07, 2012 4:44 pm    Post subject: Re: Farmall M Hydraulic Pump out put shaft seal Reply to specific post Reply with quote
do you remember if it is left handed thread?
David G
PostPosted: Sun Oct 07, 2012 4:51 pm    Post subject: Re: Farmall M Hydraulic Pump out put shaft seal Reply to specific post Reply with quote
Both ends are right hand thread. I put the tractor in gear when taking the transmission end off. The pump requires you to take pump apart.
truckerlary
PostPosted: Sun Oct 07, 2012 5:46 pm    Post subject: Re: Farmall M Hydraulic Pump out put shaft seal Reply to specific post Reply with quote
You don't have to take the pump apart. Just stick a rod of somekind down the oil fill hole to keep the pump from turning while you remove the coupling.
iowa steve
PostPosted: Sun Oct 07, 2012 6:46 pm    Post subject: Re: Farmall M Hydraulic Pump out put shaft seal Reply to specific post Reply with quote
i just changed mine,used a pipe wrench on transmision side and a chunk of steel and a hammer on pump side,put the punch(steel)on the slot and use the hammer till it gets lose, they were very tight but once it broke free it came right off.
pete 23
PostPosted: Sun Oct 07, 2012 8:09 pm    Post subject: Re: Farmall M Hydraulic Pump out put shaft seal Reply to specific post Reply with quote
Sticking a rod down the fill will only get you a rod sticking in the reservoir. You have to take the pump out of the reservoir and put a rod in the inlet of the pump. But, why not just give that coupling a few good raps with a hammer and a brass drift. That will most of the time get them loose.
charlieu
PostPosted: Mon Oct 08, 2012 4:18 am    Post subject: Re: Farmall M Hydraulic Pump out put shaft seal Reply to specific post Reply with quote
Here is a picture of a tool made for removing the drive nut. With the tractor in high gear and the brakes set you can unscrew the drive nut from the tramission counter shaft. With the square key of the tool in the slot of the nut, as you put a little pull on the tool take a hammer and tap on the nut.
I also have a tool made for removing the nut from the pump, but I can't find the picture. I took an old inpact socket that I welded a piece of key stock to that fits the nut and with the air impact wrench I have been able to remove the nut from the pump without any disassembly of the pump assembly.
Hope this helps, charlie
