| Author |
Message |
ironman53 New User
Posted: Sun Oct 07, 2012 8:42 pm Post subject: JD A |
HI. Im trying to remove parts from a jd a tractor and I need some help. I need help getting the flywheel and block off. I cant get a wrench on the nuts on yhe flywheel and I have all the nuts removed from the block but cant budge it. Afraid to hit it to hard and brake it. Thank You for any help you can give. Its a mid 40's styled A. Thanks. Terry. |
| Back to top |
El Toro Tractor Guru
Posted: Mon Oct 08, 2012 5:17 am Post subject: Re: JD A |
You need to put your request over on the JD forum as you will get a lot of responses to help you over there. Hal |
| Back to top |
Posted: Mon Oct 08, 2012 5:32 am Post subject: Re: JD A |
If you have dowels on that tractor they may be the problem. If you're using a suitable hoist to lift the engine you could sway the block from side to side easily so don't break anything. You also may need to support the rear of the tractor under the drawbar to keep it from flipping backwards once the engine is pulled. You may see a slight opening at the dowels from the swaying and you can use a pinch bar or big screwdriver to move the engine off the dowels. I would use lubri-plate on the dowels when reinstalling the engine. Hal |
| Back to top |
greenmech Long Time User
Posted: Mon Oct 08, 2012 6:21 am Post subject: Re: JD A |
You will need a special flywheel wrench that fits behind the flywheel. E-bay usually had them. Or maybe a couple universal joints may work. On the block,make sure the oil line to the tappets is disconnected. Are the 4 bolts underneath out,and the ones on the side? Try a pry bar between the frame and the underside of the block to work it loose.A little PB Blaster may help. Ron Mn |
| Back to top |
Mark-Ia Long Time User
Posted: Mon Oct 08, 2012 4:32 pm Post subject: Re: JD A |
Did you remove the bolts on the block that go up from below??? |
| Back to top |
Kent Petersen Long Time User
Posted: Wed Nov 21, 2012 10:37 am Post subject: Re: JD A |
from what you are telling this guy i know that you dont know the frist thing about a John Deere 2 cyl whay not saved it for the ones you do know something about |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
