Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
plowing with a semi-mtd plow
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley
MoMike
PostPosted: Mon Oct 08, 2012 3:51 am    Post subject: plowing with a semi-mtd plow Reply to specific post Reply with quote
I have a question for those that still plow. When you have a narrow strip left in the center of your land, say 1 or 2 bottoms wide do you drop the front down and raise the rear or lower the rear and plow with the back bottome? I haven't been around plowing for over 25 years and we used a 3pt plow at that time. I plowed a patch for wheat the other day and I don't like the way the center dead furrow came out, seems awfully wide to me. Advice welcomed and thanks.
rrlund
PostPosted: Mon Oct 08, 2012 4:13 am    Post subject: Re: plowing with a semi-mtd plow Reply to specific post Reply with quote
I lower the front and raise the back. Can't raise it all the way up,but I try to get it a few inches higher than the other furrow.
Dave Sherburne NY
PostPosted: Mon Oct 08, 2012 4:59 am    Post subject: Re: plowing with a semi-mtd plow Reply to specific post Reply with quote
When I was doing a lot of plowing with a variable width plow that wasn't much of a problem . But without the variable width I would lower the front but just enough to knock the top of the strip. The secondary tillage, a disc or drag will take care of that strip and you won't wind up with the big ditch.
RGMartin
PostPosted: Mon Oct 08, 2012 5:13 am    Post subject: Re: plowing with a semi-mtd plow Reply to specific post Reply with quote
Dave Sherburne NY wrote:
(quoted from post at 08:59:19 10/08/12) But without the variable width I would lower the front but just enough to knock the top of the strip. The secondary tillage, a disc or drag will take care of that strip and you won't wind up with the big ditch.
+1, or leave the double dead furrow, and plow into it next year.
johnpop1
PostPosted: Mon Oct 08, 2012 6:08 am    Post subject: Re: plowing with a semi-mtd plow Reply to specific post Reply with quote
Grew up in Smyrna and going there today to bury my cousin
Richard Hare
PostPosted: Mon Oct 08, 2012 6:15 am    Post subject: Re: plowing with a semi-mtd plow Reply to specific post Reply with quote
Lower the front,... but if you cut your last furrow 'up' shallower, when you plough back 'down' a bit deeper, you won't leave much sod showing if parts get ploughed back.
hope this makes sense!
Mike Aylward
PostPosted: Mon Oct 08, 2012 6:32 am    Post subject: Re: plowing with a semi-mtd plow Reply to specific post Reply with quote
When plowing the next to the last round I like to shallow the plow some so the trench isn't as deep. Then take the front of the plow and just knock off the last bit of unplowed ground. Leaves a clean, neat dead furrow that isn't tremendously deep. I've seen many that just left their plows set the same and ended up with a 15 inch or deeper dead furrow. Absolutely no need for that. Mike
paul
PostPosted: Mon Oct 08, 2012 7:20 am    Post subject: Re: plowing with a semi-mtd plow Reply to specific post Reply with quote
Lower the front all the way, rear tends to be about 3/4 up.
If the soil allows (not too wet or too much trash in it) I plow the resulting furrow closed by making an extra round with the front bottom throwing plowed dirt back into the furrow.
--->Paul
JMS/.MN
PostPosted: Mon Oct 08, 2012 8:02 am    Post subject: Re: plowing with a semi-mtd plow Reply to specific post Reply with quote
What the others say, and especially paul"s advice about making another round. Dead furrows are a PITA- get rid of them.
Dave Sherburne NY
PostPosted: Mon Oct 08, 2012 9:19 am    Post subject: Re: plowing with a semi-mtd plow Reply to specific post Reply with quote
Maybe I'll see you there.
Sid
PostPosted: Mon Oct 08, 2012 12:37 pm    Post subject: Re: plowing with a semi-mtd plow Reply to specific post Reply with quote
Paul, I have tried that plowing sod and keep making a mess. What do I need to then?
I grew up with a disc plow and thought I knew how to plow. Boy do I make a mess with a "bottom plow, when I try to plow in dead furrow.
David Snipes
PostPosted: Mon Oct 08, 2012 1:20 pm    Post subject: Re: plowing with a semi-mtd plow Reply to specific post Reply with quote
Hey MoMike, are you connected with MoMike Demolition in Spokane, Wa?
MoMike
PostPosted: Mon Oct 08, 2012 4:16 pm    Post subject: Re: plowing with a semi-mtd plow Reply to specific post Reply with quote
Afraid not, the closest I came to that part of the country is delivering freight and marrying a girl from the northwest.
paul
PostPosted: Mon Oct 08, 2012 5:31 pm    Post subject: Re: plowing with a semi-mtd plow Reply to specific post Reply with quote
Yup, you are right, in chunky sod, or heavy cornstalk trash, or in wet conditions, plowing that deadfurrow back in can be next to impossible.
--->Paul
Bobl1958
PostPosted: Tue Oct 09, 2012 1:06 pm    Post subject: Re: plowing with a semi-mtd plow Reply to specific post Reply with quote
May not be something that will work for you, but I always leave a couple of rounds, and then hit it with the offset disc, or chisel it. Saves having a dead furrow. I also do the corners that way as well. ( we plow round and round in this country, when we plow) With a good semi mount, like the other say, just raise up the rear and you can almost eliminate the dead furrow that way as well. Just takes a little practice. However, with a small 2 or 3 bottom 3 point, it will be hard to do. Bob
Post new topic    Yesterday's Tractors Forum Index -> Implement Alley All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
