| Author |
Message |
JohnDeereJimOhio Long Time User
Posted: Mon Oct 08, 2012 4:37 am Post subject: Trouble pulling Hubs off a John Deere G |
I know this topic has been covered many times but just looking for a few other ideas. I am re-doing my 51 GW and got the rim and tire off yesterday. However I can not get the hub and center to move. I have been appling lube to it for several months off and on and I tried the heat and beat method. I was thinking about taking a thick piece of channel and setting it across the end of the axel and two pieces of all thread and making a puller so it has constant pressure. My dad recomended a porta-power however I dont want to put that pressure on the rear end and crack the casting.... What do you guys think? I have also spun the tire fast and then hit the brake to try and bust loose the hub.. Anyother ideas will be appriciated. |
| Back to top |
JDBert Regular
Posted: Mon Oct 08, 2012 5:37 am Post subject: Re: Trouble pulling Hubs off a John Deere G |
Start by taking the cast off the hub, clean the axle up good and then you can use your idea of the channel and all thread. |
| Back to top |
Bob Collins Long Time User
Joined: 28 Apr 2000 Posts: 1115 Location: Union City, Michigan
Posted: Mon Oct 08, 2012 5:51 am Post subject: Re: Trouble pulling Hubs off a John Deere G |
You would be better off using three sticks of all-thread and using the hub clamp on the outer end and the 3 holes in the hub. The heavy channel or plate goes against the end of the axle, as you said. It will be much more stable and the extra threaded rod will be needed, we are talking a lot of force involved. Good luck. |
| Back to top |
Rusty wheel Long Time User
Posted: Mon Oct 08, 2012 6:19 am Post subject: Re: Trouble pulling Hubs off a John Deere G |
Hey Jim I have a puller made up for stubborn hubs. If you're gonna make one use square head set screws for the theaded rods instead of all thread. All thread is too soft. Square heads come up to 10 or 12 inches long. I know ist's quite a drive but you're welcome to use mine. RW |
| Back to top |
Posted: Mon Oct 08, 2012 7:53 am Post subject: Re: Trouble pulling Hubs off a John Deere G |
Rusty Wheel Where are you located? Could you up load some pics of it so maybe it will give me an idea how to build one? |
| Back to top |
Posted: Mon Oct 08, 2012 7:54 am Post subject: Re: Trouble pulling Hubs off a John Deere G |
JDBert i have the rim off and i have all the nuts off the center but still can not remove it either... |
| Back to top |
Christopher S. Regular
Posted: Mon Oct 08, 2012 8:27 am Post subject: Re: Trouble pulling Hubs off a John Deere G |
We found a piece of pipe that would slip over the axle and drove the hub clamp assembly farther onto the axle. Once it started moving in, it was then easier to begin working it off the axle using the puller. |
| Back to top |
Machinery-Man Tractor Expert
Posted: Mon Oct 08, 2012 10:10 am Post subject: Re: Trouble pulling Hubs off a John Deere G |
Friends of mine have made those heavy plate pullers, however I've had better luck with wire brushing with a drill buffing up the axles as close to the collar as possible. Then use a vibarting type chisel trying to get the collar to jar out the crud under it and get it to move back and forth a small amount and keep increasing the movement and you will get it over the cleaned area and it will slip off by hand....you have to removed the compression collar. Now having said that you might find in going back that you will have a hard time keeping it tight. Some put was paper under the collar. |
| Back to top |
Posted: Mon Oct 08, 2012 10:28 am Post subject: Re: Trouble pulling Hubs off a John Deere G |
Jim, I'm southwest of columbus just outside of the 270 outerbelt. I'll try to get some pics loaded. I counted the splines of the hubs I have and I think they're for an A. One might be for a G. I think the splines on the pulling tractor axel is 14 but I'll count them again. RW |
| Back to top |
donwisc Guest
Posted: Mon Oct 08, 2012 3:15 pm Post subject: Re: Trouble pulling Hubs off a John Deere G |
had the same issue with an old G and what worked was using the clamp collar like Bob Collins suggested. I will add one thing after you have pressure on the collar, find a piece of round that will go thru the clamp collar bore and with a sledge give it couple good wacks, a little vibration goes a long way in these cases. Good luck |
| Back to top |
