Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Moisture gathering in the bowels!
Post new topic    Yesterday's Tractors Forum Index -> Case and David Brown
chuck machinist
PostPosted: Mon Oct 08, 2012 5:15 am    Post subject: Moisture gathering in the bowels! Reply to specific post Reply with quote
I think it would be an appropriate time for all of us to check the moisture levels in our herds,old and newer ..I.E. motors and trannys,and hydraulic systems, since there has been a lot of talk about it on the forum this year. Best of luck. Chuck
Pastor John
PostPosted: Mon Oct 08, 2012 9:44 am    Post subject: Re: Moisture gathering in the bowels! Reply to specific post Reply with quote
Just curious little brother better does moisture always seek the lowest level in the transmission or oil pan? Does the tractor need to sit for a period of time before you tap off the water?
Since the SC sits over the winter is it better to check for moisture in the fall or spring?
I had an experience with antifreeze (very small amount)when I changed the oil in the SC the first time. I was concerned initially but it never showed up again in following oil changes. I recall the previous owner telling me he pulled the head and ground the valves. I assume it was at that time some antifreeze found its way to the pan and the oil.
Going out to winterize the SC this afternoon. Gas treatment and antifreeze check.
tomturkey
PostPosted: Mon Oct 08, 2012 11:12 am    Post subject: Re: Moisture gathering in the bowels! Reply to specific post Reply with quote
Oh yes a new fall ritual, just like maple trees in the spring, we tap tractors in the fall to let the water out. Hope all is well with Chuck and John. gobble
Pastor John
PostPosted: Mon Oct 08, 2012 1:22 pm    Post subject: Re: Moisture gathering in the bowels! Reply to specific post Reply with quote
I'm thinking we can rewrite the operating manuals.
Anything to get little brother chattering!
jon f mn
PostPosted: Mon Oct 08, 2012 3:26 pm    Post subject: Re: Moisture gathering in the bowels! Reply to specific post Reply with quote
Water always settles to the bottom. It can settle out over night or take a few days depending on the oil. When you get water depends on how you use it and what the weather is like where you live. If you use the tractor hard for a day once in a while that will usually get it hot enough to get the water out. Water is more of a problem on tractors not used much because they don't get hot enough to cook it out. Here in Mn we get water over winter from the cold weather so I drain mine in the spring.
View user's profile AIM Address
chuck machinist
PostPosted: Mon Oct 08, 2012 5:06 pm    Post subject: Re: Moisture gathering in the bowels! Reply to specific post Reply with quote
Couldn't get that archive story out of my head about the D in Indiana this past winter when the fellow couldnt move her, cause she had a block of frozen water in the transmission.and looking at all the early freeze conditions developing over the country I thought i would shake a coconut or two. doing well here ,two days of solid rain ,no complaints Chuck
IA Roy
PostPosted: Tue Oct 09, 2012 10:14 pm    Post subject: Re: Moisture gathering in the bowels! Reply to specific post Reply with quote
I bought a DC from a friend had added antifreeze to the transmission. I didn't think about it, but it was too thin to keep from freezing. When I found out it was frozen. I waited till the temp got above freezing one day, and got it moving. I drove it down the road about a half mile and put it in the heated garage. I drained 5 or 6 gallons of slush out of it, and let it sit a day. No damage that I know of. My FIL had a Farmall M that froze and cracked the rear end housing. He had it welded or brazed to prevent lube from leaking.
