Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
Weathered shovel handles
Post new topic    Yesterday's Tractors Forum Index -> Tool Talk
Stan in Oly, WA
PostPosted: Mon Oct 08, 2012 8:16 am    Post subject: Weathered shovel handles Reply to specific post Reply with quote
I picked up two shovel handles from a pile of items someone had put at the curb with a "Free" sign. I have more than enough shovels and other tools which use such handles, and plenty of replacement handles, too. The reason I picked them up was because they are so weathered---gray and cracked from dryness---that I wanted to see if they could be restored. Should I soak them in water, then dry and oil them, or should I just oil them with linseed/tung/some other oil, or do something else entirely? It's just to satisfy my mild curiosity, and the chances of me even getting around to it are not high. But, I wouldn't mind knowing.
Stan
old
PostPosted: Mon Oct 08, 2012 8:34 am    Post subject: Re: Weathered shovel handles Reply to specific post Reply with quote
Dip them in a good oil based varnish. Ya dipping them my be hard to do but that is one of the best ways to make sure it soaks in deep. There is a place just up the road from me that dip paints all there boat trailers and they do so and have done so for decades.
showcrop
PostPosted: Mon Oct 08, 2012 8:39 am    Post subject: Re: Weathered shovel handles Reply to specific post Reply with quote
I would sand them first, Not going crazy with it, but some fairly coarse first to take down the ridges, then some finer grade to smooth it. Then apply the preservative.
Glenn F.
PostPosted: Mon Oct 08, 2012 9:39 am    Post subject: Re: Weathered shovel handles Reply to specific post Reply with quote
Linseed oil
Hal/Eastern WA
PostPosted: Mon Oct 08, 2012 10:51 am    Post subject: Re: Weathered shovel handles Reply to specific post Reply with quote
What I like to do is soak my wooden handles in boiled linseed oil. I have a PVC tube with a cap on one end that works well. After soaking a few days, I let the handle hang to drip dry. Unless a handle is really far gone (like rotten), this procedure makes them a lot nicer. With a little sanding sometimes, the handles last a lot longer and feel like new ones. Good luck!
Bret4207
PostPosted: Mon Oct 08, 2012 12:48 pm    Post subject: Re: Weathered shovel handles Reply to specific post Reply with quote
Sand it down and put the linseed to it.
36 Coupe
PostPosted: Mon Oct 08, 2012 5:05 pm    Post subject: Re: Weathered shovel handles Reply to specific post Reply with quote
New boat oars have no varnish on the handles.Varnish on an axe handle will give you sore hands.Boiled linseed oil is the best and keep them out of the weather.Keep wood handled tools out of heated buildings.Heat makes the wood shrink and you will learn where the term fly off the handle comes from.
Pale Rider
PostPosted: Mon Oct 08, 2012 7:18 pm    Post subject: Re: Weathered shovel handles Reply to specific post Reply with quote
Offer them to the county. They should be in good enough shape to lean on. No danger they will be used.
showcrop
PostPosted: Tue Oct 09, 2012 3:24 am    Post subject: Re: Weathered shovel handles Reply to specific post Reply with quote
36 coupe wrote:
(quoted from post at 18:05:12 10/08/12) New boat oars have no varnish on the handles.Varnish on an axe handle will give you sore hands.Boiled linseed oil is the best and keep them out of the weather.Keep wood handled tools out of heated buildings.Heat makes the wood shrink and you will learn where the term fly off the handle comes from.
Along with the heat of a heated building comes some moisture from the occupants. Yes, it is still drier than in the summer, but much higher humidity than outdoors in mid-winter. So be careful when swinging that axe in mid winter.
Stan in Oly, WA
PostPosted: Tue Oct 09, 2012 7:05 am    Post subject: Re: Weathered shovel handles Reply to specific post Reply with quote
The coastal climate in the Pacific NW is the opposite of how you describe yours. Here, late summer and fall are the only dry times of the year, except for a very few days during the winter when the temp is low enough to prevent the air from holding a lot of moisture. In general, November through June is the rainy season. Those of us who can stand it like it a lot; the rest drink, or leave.
Stan
36 Coupe
PostPosted: Tue Oct 09, 2012 3:08 pm    Post subject: Re: Weathered shovel handles Reply to specific post Reply with quote
Our kitchen runs 50% humidity all winter.80 to 90% in summer.Chairs nearest the wood cook stove come unglued.A wood handled hammer I keep in the truck gets loose in the summer, during cold weather it tightens up so heat seems to be a factor, not humidity.
ss55
PostPosted: Sat Oct 13, 2012 11:06 am    Post subject: Re: Weathered shovel handles Reply to specific post Reply with quote
Spar varnish works well.
