| Author |
Message |
Ole Johnny Regular
Posted: Mon Oct 08, 2012 11:15 am Post subject: 12 volt ssystem on John Deere 2 banger |
Do you replace the starter on an older John Deere 2 cylinder when you go to 12 volts from 6 volts?? |
| Back to top |
biggear New User
Posted: Mon Oct 08, 2012 12:25 pm Post subject: Re: 12 volt ssystem on John Deere 2 banger |
No run the 6 volt it will spin a lil faster but will last a long time...promise |
| Back to top |
730d se Tractor Expert
Posted: Mon Oct 08, 2012 1:27 pm Post subject: Re: 12 volt ssystem on John Deere 2 banger |
Unless you like replacing the bull nose on the starter and/or the ring gear, it is wise to have it rewound to 12 volts. |
| Back to top |
Ole Johnny Regular
Posted: Mon Oct 08, 2012 2:27 pm Post subject: Re: 12 volt ssystem on John Deere 2 banger |
What would cause these failures?? |
| Back to top |
BushogPapa Tractor Guru
Posted: Mon Oct 08, 2012 3:24 pm Post subject: Re: 12 volt ssystem on John Deere 2 banger |
If you have a basically stock JD 6V 2-Cylinder..12V will spin it pretty fast...
You might tame it a little by using smaller Battery Cables, for more resistance, to get some voltage-Drop...
I never like to "Jump" my JD "B" with 12V..it spins it over mighty fast..
Ron.. |
| Back to top |
jd b puller Tractor Expert
Joined: 07 Jul 2001 Posts: 3165 Location: North Carolina
Posted: Mon Oct 08, 2012 4:23 pm Post subject: Re: 12 volt ssystem on John Deere 2 banger |
If you're replacing the bull nose on the starter you don't have it timed right. It's firing too soon before TDC and at the slower cranking speeds, it's building pressure and kicking back on you.
Pull the starter you have off, clean up the commutator, put new brushes in it and throw 12V at it.
Another thing you can do that will help is to hit the starter with the ignition off, once it's rolling, then hit the key,.
| Back to top |
Rusty wheel Long Time User
Posted: Mon Oct 08, 2012 4:39 pm Post subject: Re: 12 volt ssystem on John Deere 2 banger |
Shouldn't hurt anything as long as you don't have to crank on it too long to get it started. |
| Back to top |
Ole Johnny Regular
Posted: Mon Oct 08, 2012 6:25 pm Post subject: Re: 12 volt ssystem on John Deere 2 banger |
Thats what I thought Ray,, Thanks for the info.. |
| Back to top |
Loosehandle Regular
Posted: Tue Oct 09, 2012 4:36 am Post subject: Re: 12 volt ssystem on John Deere 2 banger |
If you need to crank it that fast there must be somthing else wrong. |
| Back to top |
Ole Johnny Regular
Posted: Tue Oct 09, 2012 4:43 am Post subject: Re: 12 volt ssystem on John Deere 2 banger |
It's a hand crank now and has too much compression for me to man handle like i did when it was 6 to 1 compressiion. Im changing it to electric start and was concerned about using a alternator and 12 volt battery on it but using the 6 volt starter still. I knowI could get a 6 volt starter but then I would have to have a 6 volt GENERATOR and I dont want that. |
| Back to top |
48farmall Regular
Posted: Sat Oct 13, 2012 5:56 pm Post subject: Re: 12 volt ssystem on John Deere 2 banger |
I"ve been running mine on 12V for a long time now. No problems. I"ve never had any problems using 12V on 6V starters on anything. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
