| Author |
Message |
Danny Helton Regular
Posted: Mon Oct 08, 2012 1:45 pm Post subject: Sears Garden Tractor Equipment |
Has there anybody on here tried to adapt sears equipment to a 1200 Cub Cadet.Thanks |
| Back to top |
steve_in_mo Guest
Posted: Mon Oct 08, 2012 2:00 pm Post subject: Re: Sears Garden Tractor Equipment |
The Sears equipment uses a smaller-than-Category-O three point system but you probably already knew that.
The easiest way would be to buy a Sears tractor.
The next easiest way would be to cut off the back of a Sears tractor frame, weld up some brackets, install the Sears three-point setup and bolt it all to the back of the CC. |
| Back to top |
ShadetreeRet Tractor Expert
Posted: Mon Oct 08, 2012 5:57 pm Post subject: Re: Sears Garden Tractor Equipment |
Why ruin a good tractor frame? Since fabricating is required anyway, simply look at how a Sears tractor is made and fabricate a hitch attachment. Or use bushings to adapt the hitch pins on the Sears equipment to the CC. |
| Back to top |
El Toro Tractor Guru
Posted: Tue Oct 09, 2012 4:57 am Post subject: Re: Sears Garden Tractor Equipment |
I made this hitch adapter so the plow off my Viking walk behind garden would mount on my Ward's tractor that has a sleeve hitch. I also made this H hitch so I can tow my lawn cart and log splitter with the sleeve hitch. Hal
| Back to top |
Posted: Tue Oct 09, 2012 5:35 am Post subject: Re: Sears Garden Tractor Equipment |
Here are more pics of the plow adapter hitch. Hal
PS: The depth control lever came with the plow.
| Back to top |
steve_in_mo Guest
Posted: Tue Oct 09, 2012 8:19 am Post subject: Re: Sears Garden Tractor Equipment |
You are right, but there are a lot of those old frames around. |
| Back to top |
t.r.k. Guest
Posted: Wed Oct 10, 2012 6:46 pm Post subject: Re: Sears Garden Tractor Equipment |
To add to what Steve_in_Mo said, If you look at the archived photos on some of the Cub Cadet websites, you should be able to find 2 or 3 CCs that have had the Sears 3-point added to them. Apparently, the rear plate the 3-point bolts on is removeable on some Sears models and can be bolted between the frame rails of-I Think-a narrow frame Cub Cadet. Bolting them in is lots better than welding all kinds of crap to a rather collectable tractor frame. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
