| Author |
Message |
Murray2 Regular
Posted: Mon Oct 08, 2012 3:25 pm Post subject: Rust on interior of rim |
Removed the tires off the rims today. One tire was loaded with calcium, previously had leaked. The interior of the rims is fairly rusty. Started to clean up with wire brush. What type of paint or good sealer could be applied, so as not to damage a new tube. Thanks, Murray |
| Back to top |
Royse Tractor Expert
Posted: Mon Oct 08, 2012 3:58 pm Post subject: Re: Rust on interior of rim |
I used Rustoleum primer and paint on mine.
There is also a rubber rim band you can put around the rim under the tube. |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50476 Location: Lake of the Ozarks area of MO
Posted: Mon Oct 08, 2012 4:40 pm Post subject: Re: Rust on interior of rim |
The best thing I have found is the spray on bed liner stuff. It is made to hold up to a lot of stuff and in theory should hold up to most any thing that would be spilled in the bed of a truck so it holds up well on the inside of a rim. I have used it many many times. Plus if you want to go the extra step get it rhino lined and it has a life time warranty |
| Back to top |
Billie R. Smith Regular
Posted: Mon Oct 08, 2012 6:46 pm Post subject: Re: Rust on interior of rim |
One of mine is wrapped with duct tape. |
| Back to top |
russb wa Regular
Posted: Mon Oct 08, 2012 9:19 pm Post subject: Re: Rust on interior of rim |
Zinc Chromate primer has some sort of chemistry going on. Thats what I recommend. Then paint on top. |
| Back to top |
souNdguy Tractor Guru
Posted: Tue Oct 09, 2012 4:53 am Post subject: Re: Rust on interior of rim |
clean it up good.
electrolysis is good if you have a place to put the rim ... otherwise chemicals like naval jelly or driveway iron rmeover / clr will eat it.. ( phosphoric acid )
once rust is gone.. weld or braze fix any holes or thin spots.
then prime and paint.
some like rusty metal primers and rust control paints by rustoleum and others. can also go for epoxy paints.. some rust control sealers like por15 are good.. and go what others say and use a sealing or ruberizing undercoating.. cold zinc finishes.. etc.. lots of preps.
pitting, once cleaned up and primed and painted shouldn't other a tube. if you weld a patch on and can't grind it good.. do as another poster said.
after paint is cured.. roll some duct tape in and around it... it DOES work.. :)
i found a boot/cut up tube taped to the inside of a rim before.. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
