F12 gaskits
smiddleton
PostPosted: Mon Oct 08, 2012 7:14 pm    Post subject: F12 gaskits Reply to specific post Reply with quote
I am in the process of restoring a F12 that has been in the family since new. Wondering if anyone has any idea where I can find gaskit for the transmission cover and seals for the axle, pto and brake shafts. Have been looking on the web but have had no luck.
Old weldor
PostPosted: Mon Oct 08, 2012 7:33 pm    Post subject: Re: F12 gaskits Reply to specific post Reply with quote
Have you tried Rice Equipment in Clarion Pa. Or The Fordson House ?
Athol Carr
PostPosted: Mon Oct 08, 2012 8:20 pm    Post subject: Re: F12 gaskits Reply to specific post Reply with quote
For the transmission case etc, I purchased a sheet of cork gasket material and cut one to fit, has worked well for 12 years so far.
gene bender
PostPosted: Tue Oct 09, 2012 1:20 am    Post subject: Re: F12 gaskits Reply to specific post Reply with quote
Seals arent any problem just take the old one or measure the od and ID and any part store can get new ones. Buy some gasket material and make your own not hard to do.
smiddleton
PostPosted: Tue Oct 09, 2012 8:18 am    Post subject: Re: F12 gaskits Reply to specific post Reply with quote
Thanks for the reply. I have tried those two and the only cary stuff for the engine. Can"t find anything for the Trans.
Nebraska Kirk
PostPosted: Tue Oct 09, 2012 4:47 pm    Post subject: Re: F12 gaskits Reply to specific post Reply with quote
You will save a lot of money by making your own gaskets out of sheet gasket material. If you get a head gasket kit, it includes the head, manifold, oil pan and valve cover gaskets, Victor part number is FS1396. All other gaskets can easily be cut out of gasket material. McMaster-Carr carries vegetable fiber gasket material in 1/16", 1/32" and 1/64" thicknesses, 3 feet wide and any length you want. All you will need is a pencil, heavy-duty scissors a small hammer and a cheap set of hole punches. Just lay the part on the gasket material, trace around it and cut out the gasket, use the hole punches for bolt holes. Works like a charm, I have made many gaskets this way.
John B.
PostPosted: Tue Oct 09, 2012 5:54 pm    Post subject: Re: F12 gaskits Reply to specific post Reply with quote
When I restored my F14 30 years ago I just put some silicon under the transmaission cover it won't squeeze out and saves a lot of time trying to make a gasket. They don't use gaskets on things like that now days. Just purchase a couple of tubes of it for your caulking gun and you're ready!
smiddleton
PostPosted: Tue Oct 09, 2012 9:13 pm    Post subject: Re: F12 gaskits Reply to specific post Reply with quote
Thanks for the reply. Making the gasket I guess is
the way to go.
F-Dean
PostPosted: Wed Oct 10, 2012 4:59 am    Post subject: Re: F12 gaskits Reply to specific post Reply with quote
Use 2 layers of gasket from a roll and make 1/2 gaskets. Splice on diagonal.
