711 loader brackets for a 960
Kelly Lipinski
PostPosted: Tue Oct 09, 2012 4:17 am    Post subject: 711 loader brackets for a 960 Reply to specific post Reply with quote
I am looking for bracket specs to mount a 711 loader on a 1955 Ford 960. Any help would be much appreciated. My email is kellylipinski162@msn.com if anyone has a drawing with measurements and could email me. Thank you.
souNdguy
PostPosted: Tue Oct 09, 2012 4:24 am    Post subject: Re: 711 loader brackets for a 960 Reply to specific post Reply with quote
the hip bracket is the sticker, usually.. but perhaps not for a rowcrop.
the front hanger bracket and lower trans strap bracket are completely torchable.
normally the hanger bracket is near impossible to fab due to needing steering arm clearance on that side.
with you haveing a rowcrop, you could simply take some 1/2" plate ad a torch and sledge, and a piece of pin stock and heat/beat/ cut / weld up a side bracket that will work fine.
some pics of my 951 should give you an idea of the geometry,, close counts...
Kelly Lipinski
PostPosted: Tue Oct 09, 2012 5:37 am    Post subject: Re: 711 loader brackets for a 960 Reply to specific post Reply with quote
Thanks,
Is there any chance you could give me some hole and pin measurements.
Front Bracket - top frame bolt hole down to loader pin hole.
Hip bracket - pin down to bolt hole and offset
trans.bracket - bolt hole to bolt hole
souNdguy
PostPosted: Tue Oct 09, 2012 5:48 am    Post subject: Re: 711 loader brackets for a 960 Reply to specific post Reply with quote
i sent you some more pics as well.
yep, i can get you some measurements.
might not be today.. will likely be tomorrow afternoon, as I work dark to dark today.. not sure i have time to get em at lunch
Kelly Lipinski
PostPosted: Tue Oct 09, 2012 12:08 pm    Post subject: Re: 711 loader brackets for a 960 Reply to specific post Reply with quote
Thankyou, whenvever you can send them will be fine. Thanks again.
souNdguy
PostPosted: Tue Oct 09, 2012 1:59 pm    Post subject: Re: 711 loader brackets for a 960 Reply to specific post Reply with quote
prod me tomorrow.
hair has more grey in it than it did a few years ago... ya know...
Kelly Lipinski
PostPosted: Thu Oct 11, 2012 5:17 am    Post subject: Re: 711 loader brackets for a 960 Reply to specific post Reply with quote
soundguy,
I sent you an email also, but just wanted to remind you about getting me those measurements.
Thanks,
Kelly
souNdguy
PostPosted: Thu Oct 11, 2012 5:37 am    Post subject: Re: 711 loader brackets for a 960 Reply to specific post Reply with quote
check yer email, I sent ya a question.
Kelly Lipinski
PostPosted: Thu Oct 11, 2012 6:48 am    Post subject: Re: 711 loader brackets for a 960 Reply to specific post Reply with quote
I checked both my inbox and junk box and did not get the email? My email address is kellylipinski162@msn.com.
thanks
Kelly Lipinski
PostPosted: Thu Oct 11, 2012 6:56 am    Post subject: Re: 711 loader brackets for a 960 Reply to specific post Reply with quote
I included my email with this post.
souNdguy
PostPosted: Thu Oct 11, 2012 6:57 am    Post subject: Re: 711 loader brackets for a 960 Reply to specific post Reply with quote
yep.. same address i sent ot at 8:55am est time
i pulled brackets off a tractor to measure.. then figured.. what the heck.. I'll template them on cardboard.
thus I have the cardboard templates to mail you.. should make duping the brackets much easier.
email me your snail mail address.
expect a large envelope from chris britton in florida in a few days after sending me your address.
