| Author |
Message |
MLPANKEY Tractor Expert
Posted: Tue Oct 09, 2012 4:30 am Post subject: power |
No secret in making power take a block bore it all it can be bored stroke the crank all it can to rotate in the bottom . Set your compression low if you say 8.1 if you desire then when you get beat you can always find more power with every rebuild if you raise the compression a static point every time. |
| Back to top |
Dblair Tractor Expert
Posted: Tue Oct 09, 2012 5:02 am Post subject: Re: power |
Mitch are you back in the game ? |
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23627 Location: in front of computer
Posted: Tue Oct 09, 2012 5:05 am Post subject: Re: power |
A higher compression ratio is usually associated with higher
peak combustion pressure and more efficient use of the power
stroke due to the higher expansion ratio.
Unless of course the cam has been ground and opening the
exhaust sooner. To empty the combustion chamber sooner to
make time for more filling with a longer duration intake
event.Then the expansion ration on a 11to 1 engine maybe
similar to a short cammed 8 to 1 engine.
You can build and cam two otherwise identical engines with
the same compression pressure for example 200psi. However
one engine has a mechanical compression ratio of 8 to 1 and
the other has an 11to 1 mechanical ratio and the exact same
cam exhaust cam lobe on both engines .
Difference is the intake lobe on the cam.
The 11 to1 engine will out power the 8 to 1 engine and
operate on the same low octane fuel.
Power won't be high on the 11 to 1 engine with 200psi
compression , as it would have been with 250psi compression
. However the 200psi 11 to 1 engine walks all over the 200psi
, 8 to 1 engine. Why? |
| Back to top |
Posted: Tue Oct 09, 2012 6:26 am Post subject: Re: power |
Static and Dynamic compression ratio are not the same . A 11.1 static with a 8.1 dynamic will always get past a 8.1 static because its dynamic will always be less than its static |
| Back to top |
Posted: Tue Oct 09, 2012 6:35 am Post subject: Re: power |
I ask myshelf that every time I look at my junk setting around the garage . |
| Back to top |
JDAGJD Guest
Posted: Tue Oct 09, 2012 11:01 am Post subject: Re: power |
I never seen them pull a dyno down a pulling track, About 90% spin out anyway. Maybe, just maybe, there is more to tractor pulling than who has the most horsepower. |
| Back to top |
Posted: Tue Oct 09, 2012 11:22 am Post subject: Re: power |
Some believe that the reason they spin out is because the sled has slowed the tractor down in speed and rpms and started picking the front end up loosing hitch height and finally unloading on the wheelie bars. In that instance horsepower would have keep the ground speed , engine rpms up and sled moving . |
| Back to top |
Posted: Tue Oct 09, 2012 1:05 pm Post subject: Re: power |
just fishing Mitch ? I know you will win . |
| Back to top |
TiredA Regular
Posted: Tue Oct 09, 2012 1:08 pm Post subject: Re: power |
If you are on the wheelie bars, you missed the setup. |
| Back to top |
Posted: Tue Oct 09, 2012 4:47 pm Post subject: Re: power |
| dblair wrote: | | (quoted from post at 14:05:09 10/09/12) just fishing Mitch ? I know you will win . | If you still have my number give me a call. I have misplaced yours or I would have already called your place. |
| Back to top |
Mlkgsmer Regular
Posted: Thu Oct 11, 2012 9:17 am Post subject: Re: power |
Duh;) |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
