| Author |
Message |
carterbeauford Regular
Joined: 05 Dec 2011 Posts: 67 Location: northwestern PA
Posted: Tue Oct 09, 2012 5:44 am Post subject: B manifold compatibility |
I have a 1941 B but it has the later 4 11/16 bore, any way of telling if it was just bored out or is a late B block? I broke the exhaust manifold and had it welded, which was a mistake. I need to know which replacement manifold will fit my head and exhaust pipe, will this one fit?
http://www.davenporttractor.com/p-363-exhaust-manifold-for-john-deere-b-tractors.aspx
note the ARP manifold studs with the hex in the middle, makes installation and removal much easier. |
| Back to top |
Dodgeit Long Time User
Posted: Tue Oct 09, 2012 12:34 pm Post subject: Re: B manifold compatibility |
Your pic shows an all fuel manifold. The reference link is for a gas manifold that will work if you tractor has a serial# greater than 201,000. |
| Back to top |
Jake Winn Long Time User
Posted: Tue Oct 09, 2012 3:54 pm Post subject: Re: B manifold compatibility |
A late B block is different than a 41-early 47. It doesnt have the mounting holes drilled and tapped for the frame. The heads however will interchange along with the different style manifolds. I have a 45 B with 4 11/16 +.045 M-W style pistons, a Berry ground camshaft, head and block shaved down a bit, gas manifold and a late B carb. It makes about 26 HP on a pto dyno. |
| Back to top |
Posted: Sun Oct 14, 2012 3:58 am Post subject: Re: B manifold compatibility |
| Dodgeit wrote: | (quoted from post at 21:34:38 10/09/12)
anyone make a replacement all fuel manifold? I just missed one on eBay that wasn't even pitted
| Jake Winn wrote: | | (quoted from post at 00:54:00 10/10/12) A late B block is different than a 41-early 47. It doesnt have the mounting holes drilled and tapped for the frame. The heads however will interchange along with the different style manifolds. I have a 45 B with 4 11/16 +.045 M-W style pistons, a Berry ground camshaft, head and block shaved down a bit, gas manifold and a late B carb. It makes about 26 HP on a pto dyno. |
I must have a bored out original 1941 block then, oem 4 11/16 pistons and rings. it makes good power, pulls a 10' disc in 3rd and sometimes 4th gear on level ground. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
