| Author |
Message |
Dodgeit Long Time User
Posted: Tue Oct 09, 2012 11:06 am Post subject: 711b front rim wheel options need help |
Looking to save some weight by using a different wheel rim combo in the front. What else would mount to the spindle? Has the factory set up. Looking for something with a solid stamped rim if possible. |
| Back to top |
Nedd Long Time User
Posted: Tue Oct 09, 2012 12:14 pm Post subject: Re: 711b front rim wheel options need help |
Later 730 and 830's had 6 bolt front wheel and hub. I know they interchange with that spindle. |
| Back to top |
Posted: Tue Oct 09, 2012 12:21 pm Post subject: Re: 711b front rim wheel options need help |
Thanks |
| Back to top |
Adirondack case guy Tractor Guru
Posted: Tue Oct 09, 2012 1:43 pm Post subject: Re: 711b front rim wheel options need help |
I doubt you would save 10# with the 30/70 series setup. The hubs were rally HD, plus you have the weight of a solid pressed steel wheel, verses a rim with 4 lugs.
Loren |
| Back to top |
Posted: Tue Oct 09, 2012 4:05 pm Post subject: Re: 711b front rim wheel options need help |
| Adirondack case guy wrote: | (quoted from post at 16:43:57 10/09/12) I doubt you would save 10# with the 30/70 series setup. The hubs were rally HD, plus you have the weight of a solid pressed steel wheel, verses a rim with 4 lugs.
Loren |
I appreciate the reply from a Case expert. 10# off the front is the same as adding 90-100# in the back when pulling. |
| Back to top |
casecollectorsc Long Time User
Posted: Tue Oct 09, 2012 6:01 pm Post subject: Re: 711b front rim wheel options need help |
Keeping the front end on the ground keeps the drawbar level which keeps the skid up and easier to pull. 200# of weight on my L on the front axle made it go farther than 200 on the back. |
| Back to top |
Posted: Wed Oct 10, 2012 10:30 am Post subject: Re: 711b front rim wheel options need help |
| casecollectorsc wrote: | | (quoted from post at 21:01:25 10/09/12) Keeping the front end on the ground keeps the drawbar level which keeps the skid up and easier to pull. 200# of weight on my L on the front axle made it go farther than 200 on the back. |
I'll agree with you as long as the front is coming up you don't need to lose weight up front. I need to lose weight up front to get the front up so it will float in the lighter classes. It's got that big honk'n power steering box in the front. |
| Back to top |
1031D Tractor Expert
Joined: 31 Jul 2004 Posts: 1705 Location: Southern Wisconsin
Posted: Wed Oct 10, 2012 9:34 pm Post subject: Re: 711b front rim wheel options need help |
Swap in a manual steering unit from a 400. Also, the 400 narrow front is lighter than the later ones. I have a narrow front from a 930 with 6 bolt hubs and an extra set of hubs in the shop. I used to pull my 1030 with a narrow front until I got tired of farming with it like that and rebuilt the wide front. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
