A Couple More Newbie Questions
Langus
PostPosted: Tue Oct 09, 2012 4:43 pm    Post subject: A Couple More Newbie Questions Reply to specific post Reply with quote
This weekend after walking away from the rear axle issues for a bit, we tackled the hydraulic system. Everything actually looked good except for two things that we noticed.
1- The first is that the lift shafts bushings are pretty sloppy. In trying to get the lift arms off and fix the bushings, we could not get the arms off. What is the trick to getting the arms and bushings off and then replacing them? Our manual was not much help in this area.
2 - I think they call it the quadrant? The lever that controls the Hydro flow just flops around. I looked in the manual and parts break down but I dont see where the offset of the shaft hooks to something. It does look like it has some marks on it like it used to "rub" on something but it doesnt now. I looked in the bottom of the pump area and did not see any loose parts. Does anybody have any good pics of this area?
Told you it was "Newbie Question Time!" Thanks.
miner09
PostPosted: Tue Oct 09, 2012 5:32 pm    Post subject: Re: A Couple More Newbie Questions Reply to specific post Reply with quote
Go to AGCO Parts Book.com, then View as Guest, Type in Tractor #, then go down to Massey Ferguson, click on Search, then click on Tractor #, then click on Hydraulic.(left side It will show complete break down of system. Same as your dealer parts list.
Langus
PostPosted: Tue Oct 09, 2012 5:42 pm    Post subject: Re: A Couple More Newbie Questions Reply to specific post Reply with quote
Thanks for that link. I did not know that was out there! It does look like the pictures on there are the same ones as in my parts book so maybe I just missed it. Thanks for the help!
Dan S (NY)
PostPosted: Tue Oct 09, 2012 6:28 pm    Post subject: Re: A Couple More Newbie Questions Reply to specific post Reply with quote
There should be a spring connected from the bottom of the lift cylinder to the control fork under the lift cover. If this is missing, there won't be any pressure holding the control fork against the quadrant lever shaft offset. The quadrant cork friction disk may also need replacing if the lever can freely flop around.
Sorry, don't know any really good tricks to get those lift arms off. After lots of heat, penetrating oil and pounding I have given up on a few...
Dan
Langus
PostPosted: Tue Oct 09, 2012 7:17 pm    Post subject: Re: A Couple More Newbie Questions Reply to specific post Reply with quote
That would explain they the forks just flopped around. The spring was not hooked to the forks and was just hanging from the cylinder. That also explains why the offset wasnt touching anything. Thanks!
