| Author |
Message |
grantl Regular
Posted: Tue Oct 09, 2012 5:48 pm Post subject: H brakes |
II put new brakes on my "H" and I have had to use most all of the adjustment to get them so I think they should be is tis correct? |
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18200 Location: St. Cloud, MN
Posted: Tue Oct 09, 2012 7:41 pm Post subject: Re: H brakes |
If the total clearance inside with the adjuster loose is more than about .050" the housing needs to be machined (at the surface where it bolts to the frame) so that the clearance is about .030" if this is not done the adjustment will be used up, and the braking force will not be very good either.
Stack the expander and the disks together on the bench and use a good caliper to measure the thickness. The depth of the housing should be just more than this, (by the above amount.) The housing and friction surface on the tractor as well as the expander all wear as they are used. This size increase must be repaired when servicing the brakes when they get to the end of the adjustment, or before that. Jim |
| Back to top |
Wayne in MN Long Time User
Posted: Wed Oct 10, 2012 7:23 am Post subject: Re: H brakes |
Likely you are referring to band style brakes. To adjust: apply the brakes fully, lock the pedal, set the adjusting screw on the bottom of the brake cover by turning it in until it touches the brake band then back out 1/2 turn and lock the set screw. This helps prevent the brake from dragging on the drum while driving.
Re-check your pedal free play and set to 1-1 1/2".
Drive the tractor and test the brakes to aee if they pull the tractor to one side or the other with the pedals locked together. |
| Back to top |
mkirsch Tractor Guru
Posted: Wed Oct 10, 2012 10:54 am Post subject: Re: H brakes |
Jim is describing DISK brakes.
For band brakes just adjust them until they work to your satisfaction. I wouldn't worry about how much adjustment you have left because I can pretty much guarantee that you won't run it enough to need a whole lot more adjustment in your lifetime.
It would be one thing if you were full-time farming 50 acres with it. You'd probably need to adjust the brakes a few times a year. |
| Back to top |
kevinj54 Long Time User
Joined: 04 Mar 2008 Posts: 563 Location: West Michigan
Posted: Wed Oct 10, 2012 10:57 am Post subject: Re: H brakes |
Could be his drums are worn out also |
| Back to top |
Posted: Wed Oct 10, 2012 12:21 pm Post subject: Re: H brakes |
If band ignore!! Jim |
| Back to top |
grantl Regular
Posted: Wed Oct 10, 2012 2:50 pm Post subject: Re: H brakes |
Thanks everyone I wondered what the set screw was for, also I just take it on tractor rides I had a lady walk out in front of me once and had a hard time stopping so decided it was time to work on the brakes. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
