| Author |
Message |
fordman25 New User
Posted: Tue Oct 09, 2012 7:28 pm Post subject: AIR IN 8700 SYSTEM |
Hello
I have a ford 8700 diesel tractor. The line from the tank rubbed the frame and brought air into the system I repaired the line, bled the system many times, but I cannot get it running. I bypassed the fuel tank and used a 5 gallon racing gas can with a fitting and ran it directly to the lift pump. Bled it many many more times with no luck.
I put an electric pump between the fuel can and the fuel filters. The fuel filters are brand new. It was much easier to bleed with the electric fuel pump. I am now getting good fuel at the injectors, but after doing this for several days, it will not run. It will run with starting fluid until the starting fluid is gone. I cannot believe that this tractor will not run, It has been good for 10 years, no problems. Any information would be greatly appreciated. |
| Back to top |
Tx Jim Tractor Guru
Joined: 14 Feb 1999 Posts: 13184 Location: Coyote Flats,Tx
Posted: Wed Oct 10, 2012 2:06 am Post subject: Re: AIR IN 8700 SYSTEM |
If your tractor doesn't have Dual-power I'd try and tow start it. |
| Back to top |
showcrop Tractor Guru
Posted: Wed Oct 10, 2012 4:05 am Post subject: Re: AIR IN 8700 SYSTEM |
I had a similar struggle with my 9000 this past summer, after changing filters. It started with having two gaskets at the top of the filters, which I corrected after awhile, but not before I buggered the fitting at the suction side of the lift pump. So my problem became one of sucking air, so it would run for a little bit then die. So I would look for a point where you are sucking air, and remember also that you need to be cranking fast enough. It can crank all day at 95% of adequate cranking speed without starting. |
| Back to top |
fordman25 New User
Posted: Wed Oct 10, 2012 4:54 am Post subject: Re: AIR IN 8700 SYSTEM |
Thanks for the replies,
I had not thought about towing it to start it. There still must be air in the system, but maybe it is not turning fast enough to start. |
| Back to top |
Chris in SK Regular
Joined: 31 Jan 2008 Posts: 489 Location: Saskatchewan
Posted: Wed Oct 10, 2012 10:15 am Post subject: Re: AIR IN 8700 SYSTEM |
Are you using the cold start button on the pump.....that sometimes helps? |
| Back to top |
mite-help Regular
Posted: Thu Oct 11, 2012 8:02 pm Post subject: Re: AIR IN 8700 SYSTEM |
rack stuck-- |
| Back to top |
fordman25 New User
Posted: Thu Oct 11, 2012 9:12 pm Post subject: Re: AIR IN 8700 SYSTEM |
I have not tried the cold start button, did not even think of it.
What rack would be stuck?
Thanks for the replies. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
