'53 SC: another question about 12V/dist conversion
DennisT
PostPosted: Tue Oct 09, 2012 8:48 pm    Post subject: '53 SC: another question about 12V/dist conversion Reply to specific post Reply with quote
Thanks to this forum, I've got the idea about timing, etc., when I install my Delco 1111411 right-angle drive distributor on my 1953 SC. Since my tractor has the old generator and I'm committing myself to the distributor ignition, I'm thinking of just going straight on to full 12V conversion with alternator. (1. Will my Delco distributor handle 12 volts? (I'm not sure if these came from the 6V days or later, so better ask)
2. Does anyone have a schematic or electrical drawing for what I need to end up with for full 12V conversion? I have heard that the one-wire alternators are not the best for low rpm/fast charging.
Thanks,
Dennis
View user's profile AIM Address
Christopher Mikesell
PostPosted: Tue Oct 09, 2012 9:07 pm    Post subject: Re: '53 SC: another question about 12V/dist conversion Reply to specific post Reply with quote
There should be no problem using your distributor with 12V. The only problem would be with the coil. You need to make sure that you have a 12V coil, or that you use a ballast resistor with a 6V coil.
DennisT
PostPosted: Tue Oct 09, 2012 9:29 pm    Post subject: Re: '53 SC: another question about 12V/dist conversion Reply to specific post Reply with quote
Thanks. That's what I was hoping for. I know I can find a 12V coil around here.
Until I build an alternator bracket and prepare to rewire all lights, etc., I might just run a start/run ckt. for now, and expand it all in the Spring. Maybe just positive battery-fuse-ignition switch-start button and on to coil.
Dennis
PostPosted: Tue Oct 09, 2012 9:42 pm    Post subject: Re: '53 SC: another question about 12V/dist conversion Reply to specific post Reply with quote
Also, all of the SCs and DCs were negative ground from the factory, so your conversion will be easier than most.
mattwillson
PostPosted: Wed Oct 10, 2012 12:42 pm    Post subject: Re: '53 SC: another question about 12V/dist conversion Reply to specific post Reply with quote
All you need, ignition wise is a ballast resistor from a 1980's dodge. You can use the coil you have. The resistor drops the voltage down to your ignition.
C. Amick
PostPosted: Wed Oct 10, 2012 4:41 pm    Post subject: Re: '53 SC: another question about 12V/dist conversion Reply to specific post Reply with quote
Did you look at the articles under Research and Info. on this web site? Under the topic of "Maintenance, Mechanical and How-To Information" there are several articles on 6V to 12V conversions.
mEl
PostPosted: Wed Oct 10, 2012 4:54 pm    Post subject: Re: '53 SC: another question about 12V/dist conversion Reply to specific post Reply with quote
C. Amick wrote:
(quoted from post at 17:41:42 10/10/12) Did you look at the articles under Research and Info. on this web site? Under the topic of "Maintenance, Mechanical and How-To Information" there are several articles on 6V to 12V conversions.
Unless I am wrong you are replacing a Mag with the distributor setup, you will need a coil and if you are buying one why complicate things by buying a 6V and then needing a resistor to drop the voltage, right up front buy a 12 volt coil, sometimes labeled with internal resistor. All that is necessary is that the coil have appx. 4 ohms primary resistance. Hook the coil up the same polarity as your battery, If you are installing an alternator, NEG ground is the norm, - post on the coil to the post on the distributor. I have done dozens and it is so simple a cave man can do it, lol
hintocw
PostPosted: Wed Oct 10, 2012 9:15 pm    Post subject: Re: '53 SC: another question about 12V/dist conversion Reply to specific post Reply with quote
A Delco alt. will fit right where the old gen. mounted without ANY aftermarket mounting brackets whatsoever; using an aftermarket bracket will just complicate things. Also, an orginal type (7/8") belt pulley will easily fit.
Greenfrog
PostPosted: Mon Oct 22, 2012 3:27 pm    Post subject: Re: '53 SC: another question about 12V/dist conversion Reply to specific post Reply with quote
I sorry, I dont' seem to see this topic on this website...Research and info....that is...
