| Author |
Message |
Larharm Regular
Posted: Wed Oct 10, 2012 6:33 am Post subject: no spark on 631 |
purchased new switch it has two lead wires both connect to terminal block one on each side of block.
there is no connection on switch to run wire direct from switch to coil like it said on early post Ford dealer faxed me a electrical diagram and it shows a relay with 2big post and 1 small. then i went there and bought a relay they sold me one with 2big post and 2small like the parts book shows anyway still no spark to coil |
| Back to top |
old Tractor Guru
Joined: 12 Mar 2000 Posts: 50434 Location: Lake of the Ozarks area of MO
Posted: Wed Oct 10, 2012 7:00 am Post subject: Re: no spark on 631 |
Sounds like you got it wired wrong still. If you can run a hot wire from the battery to the ignition side of the coil and it runs then you know your wiring is wrong. To be wired right you should have the one side of the ignition switch hooked to the map gauge and the other wire going straight to the coil |
| Back to top |
Larharm Regular
Posted: Wed Oct 10, 2012 7:38 am Post subject: Re: no spark on 631 |
will the coil take a direct 6v hook up for test from battery without damage |
| Back to top |
awhtx Tractor Guru
Joined: 16 Jan 2002 Posts: 5048 Location: Lampasas, TX
Posted: Wed Oct 10, 2012 7:46 am Post subject: Re: no spark on 631 |
The 4 post relay is correct for a 631.
One big post to battery, other to the starter. It doesn't matter which one goes where.
One small post to the starter button on trans, other to the switched side of the terminal block. It doesn't matter which goes where.
One side of terminal block- wire from key switch and wire from battery.
Other side of terminal block (the switched side)- other wire from key switch, wire to small post on starter relay and wire to coil. When the key is turned ON you have power to the starter relay and power to the coil. |
| Back to top |
Larharm Regular
Posted: Wed Oct 10, 2012 7:53 am Post subject: Re: no spark on 631 |
it is and was wired the way you mentioned i am not trying to rewire just trying to find out why no spark it run okay before the way it is wired. i will replace the relay and see if that does it |
| Back to top |
old Tractor Guru
Posted: Wed Oct 10, 2012 8:18 am Post subject: Re: no spark on 631 |
YES a 631 uses a round can coil and they are made to handle the full 6 volts of the system. Your tractor is not the old front mount weak square coil that burns out easy. As a matter of fact a round can 6 volt coil will handle 12 volts for a good long time as long as the switch never gets left on with out the engine running so YES you can safely hot wire it |
| Back to top |
awhtx Tractor Guru
Posted: Wed Oct 10, 2012 8:24 am Post subject: Re: no spark on 631 |
The starter relay has nothing to do with spark.
With the key ON do you have power to the coil? |
| Back to top |
Larharm Regular
Posted: Wed Oct 10, 2012 4:06 pm Post subject: Re: no spark on 631 |
found a bad wire to coil so now have spark |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
