| Author |
Message |
Dude with a 300 Regular
Joined: 27 Sep 2012 Posts: 44 Location: Raid City, SD
Posted: Wed Oct 10, 2012 1:42 pm Post subject: Where's My Dipstick |
How come my 1955 300 doesn't have a traditional oil dipstick to check the level. I received my manual today and it shows a dipstick just ahead of the oil filter. I have an untapped boss there and no dipstick.
Bruce |
| Back to top |
Charlie M Long Time User
Posted: Wed Oct 10, 2012 2:08 pm Post subject: Re: Where's My Dipstick |
Maybe someone changed the block? |
| Back to top |
Harold H Tractor Guru
Joined: 17 May 1998 Posts: 4051 Location: Georgia and Mississippi
Posted: Wed Oct 10, 2012 2:12 pm Post subject: Re: Where's My Dipstick |
Maby your 350 was a distillate with pet cocks. Though rare, distillate was still an option thru the 350/450/650 line of tractors.
Harold H |
| Back to top |
Posted: Wed Oct 10, 2012 2:13 pm Post subject: Re: Where's My Dipstick |
I mean your 300.
Harold H |
| Back to top |
D Slater Tractor Expert
Posted: Wed Oct 10, 2012 3:33 pm Post subject: Re: Where's My Dipstick |
Farmall 300 tractors didn't get dipsticks added until tractor serial # 9338 or engine serial # 9341. If your 300 is a lower serial # thats the answer. |
| Back to top |
sd pete Long Time User
Posted: Wed Oct 10, 2012 3:35 pm Post subject: Re: Where's My Dipstick |
Way back in the early 60's Dad bought a early 300 no dip stick on it. When he retired I bought it from him. Wasn't any tractor fuel equipment on it.
W |
| Back to top |
Posted: Wed Oct 10, 2012 4:17 pm Post subject: Re: Where's My Dipstick |
Mine is in the 7200 serial range. So how are you supposed to check the oil?
Bruce |
| Back to top |
uncle henry Regular
Posted: Wed Oct 10, 2012 4:21 pm Post subject: Re: Where's My Dipstick |
should be two pet cocks on side of the oil pan upper and lower |
| Back to top |
Berth 29 opinions Regular
Posted: Wed Oct 10, 2012 4:30 pm Post subject: Re: Where's My Dipstick |
Different tractor, but my Grandfathers Mccormick had a plug on the side of the oil pan (petcock hole) Loosen it, if oil leaked out it was not low. |
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18205 Location: St. Cloud, MN
Posted: Wed Oct 10, 2012 4:51 pm Post subject: Re: Where's My Dipstick |
Answer; the side of the oil pan has two small projections on the side. These are petcocks (valves). if you open the top valve on level ground, the oil should drip from it if it is full.
If the bottom petcock is opened and none comes out it is considered low. So keep the level between them. Filling till it comes out the top one when checking was SOP when running them hard. Jim |
| Back to top |
F BH44 Guest
Posted: Thu Oct 11, 2012 1:48 am Post subject: Re: Where's My Dipstick |
I put a dipstick in my "H". There's a cast boss that sticks out on the side of the block, just ahead of the filter. Remove the oil pan, get the sharpest drills you have, and start drilling in the center of this boss, at the correct angle down, so you'll miss the crank. Drill a bit, then open that hole up with the next size drill, then go back and drill further with the first drill, the object being not to break off a bit. I had to drill thru 2 3/4" of cast iron. Tap the hole, get a piece of 3/8" tube, as i recall, re-thread it from NPT threads to fine threads, and installthat. I got a Ford dipstick, put it in, and make sure it misses the crank. (Mine misses the crank by 3/4".) Remove all the chips and filings.
Works great, and truth be told, I check the oil much more often now. I used to check it once a year. Dipstick looks real cool too. |
| Back to top |
Jonnymac348 New User
Posted: Thu Oct 11, 2012 3:39 am Post subject: Re: Where's My Dipstick |
someone probley changed the oil pan out if it doesn't have pet cocks on the side. best answer is look in your service manual read how man Qt's it takes fill it with that and use it if your in a crunch. Just like all the new cars out there no dip stick. |
| Back to top |
Posted: Thu Oct 11, 2012 4:25 am Post subject: Re: Where's My Dipstick |
OK, mine has the two petcocks, just seems kinda half a$$ed way to do it since dipsticks had been around forever.
Bruce |
| Back to top |
mkirsch Tractor Guru
Posted: Thu Oct 11, 2012 4:49 am Post subject: Re: Where's My Dipstick |
No, not like all new cars out there.
The 300 at least has a way to visually check the oil, using the petcocks.
New cars, if this whole no-dipstick thing is true, won't have a way to check the oil at all. You're depending on the computer to "sense" that the engine has the proper amount of oil in it.
I haven't looked at a new car in almost 10 years so I have no idea if they come with dipsticks or not. I would not be surprised since most people can't be bothered to check my oil. |
| Back to top |
caseyc Long Time User
Posted: Thu Oct 11, 2012 8:05 am Post subject: Re: Where's My Dipstick |
GM did away with tranny dipsticks back in the early
2000's, not all models but too many. Ford has also
did away with tranny dipsticks around the late
2000's, again, not all models but some. I have
not run across a vehicle without an oil dipstick,
yet.
Casey in SD |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
