| Author |
Message |
BruceS. Guest
Posted: Wed Oct 10, 2012 3:34 pm Post subject: H magneto timing |
Am timing H engine with mag after rebuild. I followed the IT manual. Cannot get mag to trip on first mark on pulley, but can get it to trip between the two marks, or on the second mark. What is correct? |
| Back to top |
Janicholson Tractor Guru
Joined: 30 Jan 2004 Posts: 18201 Location: St. Cloud, MN
Posted: Wed Oct 10, 2012 4:44 pm Post subject: Re: H magneto timing |
The first mark is not TDC. The last mark should be. Advanced timing comes before that, then IIRC a mark for finding the zerk for greasing the pilot bearing. Jim |
| Back to top |
pete 23 Tractor Expert
Posted: Wed Oct 10, 2012 5:00 pm Post subject: Re: H magneto timing |
From factory, H came with two marks close together and one by itself. The two marks, first one to come around in normal direction of rotation is tdc and second is 5 degrees atdc. The lone mark is to grease pilot bearing in clutch. When fire crater pistons are installed the pulley is supposed to be marked 22 degrees before tdc which would be a little over an inch. I remember the M distance, it is 1 7/16 inch but don't remember the H for sure. Time mag to tdc if you like but I much prefer a few degrees after tdc to be safe. They have such a long impulse lag that it will still be more than enough advanced when running. I should add, that on magneto equipped engines IH also made a special impulse coupling available when using fire crater pistons. |
| Back to top |
davediehl@hotmail.com Tractor Expert
Joined: 04 Nov 2006 Posts: 1998 Location: Angola, IN (Northeast Corner)
Posted: Thu Oct 11, 2012 4:03 am Post subject: Re: H magneto timing |
I poked in video that helped me on my H.
Easier to understand.
| Back to top |
BruceS. Guest
Posted: Thu Oct 11, 2012 6:04 am Post subject: Re: H magneto timing |
Thanks for replies. Based on your comments, I think everything is OK. Great video. Thanks again. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
