| Author |
Message |
dgr427 New User
Posted: Thu Oct 11, 2012 10:36 am Post subject: JD 301 Alternator/Fan Belt |
I went to change the Alternator/Fan belt on my JD 301 and it appears that I have to remove the radiator to change the belt, is that correct? Or is there a trick? Of course I could just be an idiot and I am missing something, it has a loader on it so its hard to get a good look at every thing. |
| Back to top |
Tx Jim Tractor Guru
Joined: 14 Feb 1999 Posts: 13120 Location: Coyote Flats,Tx
Posted: Thu Oct 11, 2012 12:27 pm Post subject: Re: JD 301 Alternator/Fan Belt |
No need to remove radiator just remove frt hyd pump coupler,R&R fan belt and replace coupler. |
| Back to top |
dgr427 New User
Posted: Thu Oct 11, 2012 1:07 pm Post subject: Re: JD 301 Alternator/Fan Belt |
Yep understand about the coupler but how do you get at the
coupler without removing the radiator? |
| Back to top |
dgr427 New User
Posted: Thu Oct 11, 2012 1:08 pm Post subject: Re: JD 301 Alternator/Fan Belt |
BTW thanks for the help Jim! |
| Back to top |
Tx Jim Tractor Guru
Posted: Fri Oct 12, 2012 3:08 am Post subject: Re: JD 301 Alternator/Fan Belt |
| dgr427 wrote: | (quoted from post at 17:07:28 10/11/12) Yep understand about the coupler but how do you get at the
By removing the 2 bolts(parts key #6) and splitting the metal clamps. It would be a good idea to replace parts key #3(R45822 BUSHING 2.21 USD)
| Back to top |
buickanddeere Tractor Guru
Joined: 31 May 2003 Posts: 23624 Location: in front of computer
Posted: Fri Oct 12, 2012 5:23 am Post subject: Re: JD 301 Alternator/Fan Belt |
When in there. Take a close and honest look at the water pump pulley and alternator pulley wear. Using a wee straight edge will about scare you with the amount of wear.
A new belt cranked down tight will drive. However the belt life and bearing life will be reduced with the worn pulleys. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
