Fordson super major hydraulics
Fordson 5
PostPosted: Thu Oct 11, 2012 2:19 pm    Post subject: Fordson super major hydraulics Reply to specific post Reply with quote
Hi, I have a 1963 Fordson super major that I just finished restoring. I know that the hydraulics only work when the pto is in gear but, I have noticed that the hydraulics will not hold an implement up unless the pto is running. Should this be the case or should the hydraulics have a hold feature that keeps the implement up even when the pto is disengaged? My other tractors will hold up even when the tractor is not running as long as the lever is not moved. Thanks for your help.
Robert Major
PostPosted: Fri Oct 12, 2012 10:35 am    Post subject: Re: Fordson super major hydraulics Reply to specific post Reply with quote
Hi when the pto is not running the arms should stay up for a reasonable time. when the hydraulics are up with a load on are they bobbing up and down( correcting height) a lot? if so it could be a leaky valve or the piston seal or piston bore is damaged or both parts usually.
Those are not uncommon things to find on a super major. the hyd lift system can be a big pain in the butt on these later majors tractors sadly, they are way over complicated to the early and power major.
Regards Robert
Tony Jacobs
PostPosted: Sat Oct 13, 2012 6:17 am    Post subject: Re: Fordson super major hydraulics Reply to specific post Reply with quote
Hello Robert , I saw on an older post about serial numbers you had it was broken down by Month and Year , was that a Ford list of serial numbers ? I am looking for a serial number list for Major's and Dexta's that was originally printed by Ford . Do you have one ? Thanks Tony Jacobs
Robert Major
PostPosted: Wed Oct 17, 2012 2:41 pm    Post subject: Re: Fordson super major hydraulics Reply to specific post Reply with quote
Hi Tony
No sorry I don't have an original ford printed list. All I have is an IT shop manual and a Fordson Major history book that lists them.
Regards Robert
Majorman
PostPosted: Fri Oct 19, 2012 2:13 pm    Post subject: Re: Fordson super major hydraulics Reply to specific post Reply with quote
Hi Tony,
I may be able to help you out but I am in Australia at the moment so 3000 miles away from my books. Will not be getting back until early December if that is any help.
Tony Jacobs
PostPosted: Fri Oct 19, 2012 6:42 pm    Post subject: Re: Fordson super major hydraulics Reply to specific post Reply with quote
Thanks for letting me know , Robert . Tony
Tony Jacobs
PostPosted: Fri Oct 19, 2012 6:44 pm    Post subject: Re: Fordson super major hydraulics Reply to specific post Reply with quote
Hello Majorman , I sent you an email and my email on here is open also , when ever you get home is not a problem not in any rush . Thanks Tony
Post new topic    Yesterday's Tractors Forum Index -> Fordson All times are GMT - 8 Hours
