| Author |
Message |
1939A Guest
Posted: Thu Oct 11, 2012 4:06 pm Post subject: Unstyled or styled B for pulling |
I have a unstyle B and a a styled B would like to build one into a div 2T puller this winter which would be better what are the pros and cons thanks for the input |
| Back to top |
Josh Blackburn Regular
Posted: Thu Oct 11, 2012 4:20 pm Post subject: Re: Unstyled or styled B for pulling |
Styled b... 39 will be the lightest and can be made to look unstyled and you run the newer bigger blocks or bolt powerblock in. Low gear at 1513 i believe is rpm allowed hits 3mph easy and depending on engine size second gear is doable at 3mph, but chugging at 3mph. Unstyled case takes some bolt reloaction to put better blocks in cyclone head can be made to flow alot better than the unstyled flat head also. |
| Back to top |
1939A Guest
Posted: Thu Oct 11, 2012 4:34 pm Post subject: Re: Unstyled or styled B for pulling |
Thanks josh when i get it in tbe shop i will get ahold of you for some ideas on the engine |
| Back to top |
Early B Guest
Posted: Fri Oct 12, 2012 8:15 am Post subject: Re: Unstyled or styled B for pulling |
I have a B built by Josh that has no lack for power.Hope to have video posted soon. Josh can give you my number if you want to talk about my set up. He also stands behind his work and takes care of any problems that might come along. Jason in N.Y. |
| Back to top |
Curios Guest
Posted: Fri Oct 12, 2012 11:57 am Post subject: Re: Unstyled or styled B for pulling |
Did Josh build you a B like the one that he pulled against in Sigourney Iowa a few years back or did he build you a bigger one? |
| Back to top |
Posted: Fri Oct 12, 2012 2:43 pm Post subject: Re: Unstyled or styled B for pulling |
What b would that be? I pulled an A in 4500 and up. |
| Back to top |
jd b puller Tractor Expert
Joined: 07 Jul 2001 Posts: 3165 Location: North Carolina
Posted: Fri Oct 12, 2012 4:13 pm Post subject: Re: Unstyled or styled B for pulling |
If I had an Unstyled B to build a puller out of, I would unbolt the frame with everything ahead of the transmission case and bolt it to a 39-46 B. Then you get the later blocks and heads and still get the looks of the unstyled. The 39-40 is a 4 speed like the unstyled and the 41-46 is a 6 speed. The 39-46 is a little lighter than the 47-52, but the gears are a little faster. My 47 weighs a tick under 3200 with me on it. Many of the B's running around are 5.125" x 7.5", this will easily fit in either trans case. 5.125" is a Powerblock bored +0.125", I've sleeved to 5.375". If you're wanting to go really big, I'd go with the 47-52 as the transmission case is a little wider. For Div 2T, I'd think the 5.125" x 7.5-7.875" would be plenty. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
