M choke Cable
JohnDeereM50
PostPosted: Thu Oct 11, 2012 4:08 pm    Post subject: M choke Cable Reply to specific post Reply with quote
May be a dumb question but how do you get your hand inside the instrument panel at the right angle to put the jam nut on the choke cable on a M JD? I tried for a while and failed. Do I have to take the gas tank off or amp gauge out to get in there better? Thanks for any help.
Hotflashjr
PostPosted: Fri Oct 12, 2012 4:15 am    Post subject: Re: M choke Cable Reply to specific post Reply with quote
So I had this issue getting my starter switch all installed. I couldn't get my fat hand in there. I unbolted the two back gas tank bolts at the pedestal. I loosened the fronts but did not take them off. I made sure to shut the fuel off at the tank as I still had some in there but luckily not a full tank. I lifted the tank just enough to get my hand in there so as not to disturb the fuel line or anything else. It was still a pain but gave me the extra inch or two I needed.
Resting Relics 1
PostPosted: Sat Oct 13, 2012 2:44 pm    Post subject: Re: M choke Cable Reply to specific post Reply with quote
Hey JohnDeere M50,
Not sure about your M but the one I have the choke cable is threaded into the dash, so there is no nut. If you look in the parts book no nut is called so I would assume all M's are this way. Good Luck!
John
JohnDeereM50
PostPosted: Sat Oct 13, 2012 6:35 pm    Post subject: Re: M choke Cable Reply to specific post Reply with quote
In my M parts manual it does show a nut and the dash on the tractor isn"t threaded on mine so it must be different for some reason?
There is a 1957 420 at work currently and I looked at it and the choke cable on it is threaded into dash. My M is a 1950.
M-MAN
PostPosted: Sun Oct 14, 2012 11:19 am    Post subject: Re: M choke Cable Reply to specific post Reply with quote
It was threaded in at one time on all of them. My guess is your's was drilled out to replace it cause they coulden't get to that jam nut short of dissmanteling everything. One of mine had that problem and the previous owner just put a new cable in the all fuel hole. It was years before I realized it was in the wrong place & it's still there. I don't see any way of getting in there short of raising the fuel tank and probably removing the guage also. I would remove the battery and right side cover. The oil pipe is in the way too but a younger fellow might be able to work around that.
JohnDeereM50
PostPosted: Sun Oct 14, 2012 2:07 pm    Post subject: Re: M choke Cable Reply to specific post Reply with quote
M-MAN wrote:
(quoted from post at 20:19:19 10/14/12) It was threaded in at one time on all of them. My guess is your's was drilled out to replace it cause they coulden't get to that jam nut short of dissmanteling everything. One of mine had that problem and the previous owner just put a new cable in the all fuel hole. It was years before I realized it was in the wrong place & it's still there. I don't see any way of getting in there short of raising the fuel tank and probably removing the guage also. I would remove the battery and right side cover. The oil pipe is in the way too but a younger fellow might be able to work around that.
I kinda thought maybe that is what happened. With the help of my girlfriend and removing the fuel tank I finally got it installed....still wasn't very easy.
