| Author |
Message |
JeremyR Regular
Posted: Thu Oct 11, 2012 6:14 pm Post subject: Need help finding a part for something |
I was given a 10000lb Harbor Freight winch, by my FIL. It needs a "bearing plate" even though it has no bearings. Harbor Freight told me the part is no longer available. I hate to get rid of it as the rest is in good shape. I think one from the 8000 pound one will work. This one was named "road shock"
I keep hunting Ebay and Craig's list with no luck. I hate to junk it. would be handy to have around.
Jeremy
| Back to top |
retired farmer Long Time User
Posted: Thu Oct 11, 2012 6:26 pm Post subject: Re: Need help finding a part for something |
Whatever it is, you could probably have a machine shop make one for you. |
| Back to top |
Lou from Wi. Tractor Expert
Posted: Thu Oct 11, 2012 10:39 pm Post subject: Re: Need help finding a part for something |
See if you can get hold of Chicago Electric, they used to make them(winches), and might have some NOS parts still on the shelves somewhere, or they might know of a replacement part.If not maybe they could give you a print for it and you could have the local Iron workers make the part or you.
We make alot of our own parts, as long as we have a print or picture to go by.As an example we built a 30 ton log splitter from just a picture.
LOU |
| Back to top |
MarkB_MI Tractor Guru
Posted: Fri Oct 12, 2012 1:35 am Post subject: Re: Need help finding a part for something |
There is no "Chicago Electric". That's one of the various house brands Harbor Freight stamps on their Chinese junk. Presumably Chicago Electric is a takeoff on Chicago Pneumatic, but unlike its reputable namesake, Chicago Electric has no connection with Chicago, Illinois, USA. Apparently HF really likes Chicago Pneumatic, as they copied not one, but two of their brand names from CP, the other being the infamous "Central Pneumatic". |
| Back to top |
Stephen Newell Tractor Expert
Posted: Fri Oct 12, 2012 3:51 am Post subject: Re: Need help finding a part for something |
Its more than just a plate. You need the entire Roller Fairlead. Harbor Freight still sells wenches so I would try to fit a roller fairlead from a current model to yours. You might have to add steel or weld the fairlead to yours but I bet it can be done.
The diagram is for the smallest wench HF sells so I know it wouldn't work for you. I just thought it would give you an idea of what to look for.
| Back to top |
Billy Shafer Tractor Expert
I have a Chicago Electric generator. That a customer brought me. Fours years later I am still trying to find parts for it. You may have to toss the winch. |
| Back to top |
rustyfarmall Tractor Guru
Joined: 07 Feb 2003 Posts: 18483 Location: Southwest Iowa
Posted: Fri Oct 12, 2012 5:39 am Post subject: Re: Need help finding a part for something |
| MarkB_MI wrote: | | (quoted from post at 02:35:27 10/12/12) There is no "Chicago Electric". That's one of the various house brands Harbor Freight stamps on their Chinese junk. Presumably Chicago Electric is a takeoff on Chicago Pneumatic, but unlike its reputable namesake, Chicago Electric has no connection with Chicago, Illinois, USA. Apparently HF really likes Chicago Pneumatic, as they copied not one, but two of their brand names from CP, the other being the infamous "Central Pneumatic". |
Harbor Freight also did a rip-off of the Lincoln tombstone welder, and called it a Chicago Electric. The Folks at Lincoln were not impressed. They sued, and Harbor Freight lost. |
| Back to top |
Dalex Long Time User
Posted: Fri Oct 12, 2012 8:21 am Post subject: Re: Need help finding a part for something |
I just googled "fairlead a$$'y " and several different ones come up .Maybe you could adapt one from another brand ? It's just the roller guides for the cable, you could make different mounts for it ... |
| Back to top |
Dick L Tractor Guru
Posted: Fri Oct 12, 2012 11:12 am Post subject: Re: Need help finding a part for something |
Not all fairlead/winch rollers are mounted to the winches.
Try This
| Back to top |
JeremyR Regular
Posted: Fri Oct 12, 2012 3:35 pm Post subject: Re: Need help finding a part for something |
Its not part of the fairlead. Its a cast part that is between the drum and gear box.
Jeremy |
| Back to top |
36 Coupe Tractor Guru
Posted: Sat Oct 13, 2012 2:01 am Post subject: Re: Need help finding a part for something |
It costs money to stock repair parts.Most import machinery has no parts back up.When you can get parts the prices are sky high.When I sold stoves a new grate sold for 16.00 now its 95.00.I sold a stove that could burn coal for 250.00.The door for that stove costs 335.00 now.I see many parts marked up 100%.Son and I cleaned up the shop.I was surprised at the small engine and TV parts I have left that will never sell. |
| Back to top |
Bret4207 Tractor Expert
Joined: 15 Jan 2005 Posts: 2906 Location: St Lawrence Valley, Northern NY
Posted: Sat Oct 13, 2012 2:31 am Post subject: Re: Need help finding a part for something |
36- put all those parts on Ebay. They WILL eventually sell. I swear, you can find anything on there if you are patient. |
| Back to top |
jackinok Tractor Expert
Posted: Tue Oct 16, 2012 7:21 am Post subject: Re: Need help finding a part for something |
just a idea,could you take the part you have , drill it to a larger size and fit a brass bushing?if its cracked or broken,you could get it welded up probably, |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
