| Author |
Message |
GordoSD Tractor Guru
Joined: 09 Jun 2005 Posts: 6607 Location: Mitchell, SD
Posted: Thu Oct 11, 2012 7:42 pm Post subject: Husker bed 326 |
I have a 326 husker bed on ny 324 Gathering unit (corn picker).
The seller gave me a coffee can full of the 1891-P Husking pegs. Do I need to put these in the husking roll assemblies?
And I have the wagon chute clutch working thanks to you guys. |
| Back to top |
paul Tractor Guru
Posted: Thu Oct 11, 2012 8:38 pm Post subject: Re: Husker bed 326 |
Probably not. Anyohw try it without. Are there some in the rolls now, and these are extra?
If you get too aggressive with the pegs, it'll shell out some corn. For feeding cattle, a few leaves on the corn isn't a bad thing.
So, depends on what you are trying to get out of the deal I guess.
--->Paul |
| Back to top |
Leroy Tractor Guru
Joined: 09 Jan 1998 Posts: 9409 Location: Wapakoneta, Ohio
Posted: Fri Oct 12, 2012 4:42 am Post subject: Re: Husker bed 326 |
Those things were around for years in varring forms. Usage depends on what you want and the type of corn. Some corn is bred to have a very tight husk and others are bred to have a husk thay opens itself so if you have a tight husk and need clean ears for some reason then probably use them, if your corn is the loose husk type and just going to feed it then forget about them. The tight husk types with the husk on will not be able to dry out in the crib if it has a lot of moisture like ears with no husks can do and therefore more chance of spoiling. Also if you later want to run thru a sheller the husks realy slow down the shelling but I would dought that is your plan by picking. |
| Back to top |
rrlund Tractor Guru
Posted: Fri Oct 12, 2012 5:36 am Post subject: Re: Husker bed 326 |
Only if you have a good magnet in your grinder mixer. |
| Back to top |
James22 Guest
Posted: Fri Oct 12, 2012 9:07 am Post subject: Re: Husker bed 326 |
For cattle husks have excellent feed value; only superceded by the grain. Therefore unless you are concerned that the cribbed corn will not dry properly or are feeding hogs, I wouldn't use the pegs. Also as mentioned they tend to shell more corn which isn't a good thing if picking and cribbing. |
| Back to top |
Posted: Fri Oct 12, 2012 9:18 am Post subject: Re: Husker bed 326 |
Actually, the corn is for friends steer and some for bait for trail cams. The rest for winter feed for pheasants if the snow gets too deep. It comes out of food plots on another farm. |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
