Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
DC pressure plate
Post new topic    Yesterday's Tractors Forum Index -> Case and David Brown
outsidersag
PostPosted: Thu Oct 11, 2012 7:47 pm    Post subject: DC pressure plate Reply to specific post Reply with quote
Does anyone know where to get a pressure plate for a 53 DC with live power and hand cluth?
Stephen Newell
PostPosted: Thu Oct 11, 2012 8:32 pm    Post subject: Re: DC pressure plate Reply to specific post Reply with quote
Try John Saeli. email him at jsaeli@rochester.rr.com
casecollectorsc
PostPosted: Fri Oct 12, 2012 4:04 am    Post subject: Re: DC pressure plate Reply to specific post Reply with quote
I got a disc rebuilt by Hy Capacity. Maybe check with them on the pressure plate also.
longcases
PostPosted: Fri Oct 12, 2012 4:18 am    Post subject: Re: DC pressure plate Reply to specific post Reply with quote
Whats wrong with your pressure plat? Not much to go wrong with them.I have some in tractors,I think I saw a loose one the other day,I will check.
j hikemper
PostPosted: Fri Oct 12, 2012 6:03 am    Post subject: Re: DC pressure plate Reply to specific post Reply with quote
google ,,,ky clutch,they rebuild everything and ship too.........
outsidersag
PostPosted: Fri Oct 12, 2012 9:23 am    Post subject: Re: DC pressure plate Reply to specific post Reply with quote
If you get it set so it got good snap when you push it in,it wont release rite. dont want to stop and grinds going into gear
D G Wells
PostPosted: Fri Oct 12, 2012 5:57 pm    Post subject: Re: DC pressure plate Reply to specific post Reply with quote
j, Look up "Case LA Tractor Split" in the Case discussion search box and you will see how the hand clutch is put together or taken apart. The LA may be similar to the DC. ---Derrol in Texas---
DKase
PostPosted: Fri Oct 12, 2012 6:58 pm    Post subject: Re: DC pressure plate Reply to specific post Reply with quote
Do you have it out of the tractor, or just looking before you pull it appart? Sounds like one of the pins fell out. Had a 930 std. do that. Installed another pin through the hand hole. Not simple, but easier than splitting. Those wet clutches do not wear out. Problem should not be that hard to find.
Dale in nw wa.
PostPosted: Fri Oct 12, 2012 7:25 pm    Post subject: Re: DC pressure plate Reply to specific post Reply with quote
You might check the ajustment bolts or screws that work the preasures plate fingers. On my 53 DC with foot clutch one of the heads broke off and it would not go in gear> Before it broke of it was a bear to get in gear about had to shut off motor to get in gear Good luck Dale
outsidersag
PostPosted: Fri Oct 12, 2012 7:45 pm    Post subject: Re: DC pressure plate Reply to specific post Reply with quote
Its still in the tractor. I will look if a pin is out
casecollectorsc
PostPosted: Fri Oct 12, 2012 8:15 pm    Post subject: Re: DC pressure plate Reply to specific post Reply with quote
When I had mine apart, the rivets had worn off and a piece of the disc had overridden the rest of the disc, making it double in that spot. When trying to adjust, had the same problem you're having. Hy- Capacity rebuilt my disc, as they said the disc for live power DC's is hard to find?!?
dboll
PostPosted: Sat Oct 13, 2012 5:59 am    Post subject: Re: DC pressure plate Reply to specific post Reply with quote
did you adjust your pulley brake? It affects the throw on the clutch fork. If you can't fix what you have I have a 52 with live pto that I have been parting, or better yet I could sell you a pretty good 53 dc!
outsidersag
PostPosted: Sat Oct 13, 2012 7:55 am    Post subject: Re: DC pressure plate Reply to specific post Reply with quote
Its Kieth Wicks tractor. Not sure if he adjusted the pulley brake. I got a nice 53 DC, 54 SC and a 42 VC at that sale by Mitchell a couple weeks ago.
dboll
PostPosted: Sat Oct 13, 2012 5:22 pm    Post subject: Re: DC pressure plate Reply to specific post Reply with quote
I didn't hear about that sale. Maybe a good thing as I am planning on thinning out my collection instead of adding to it!
outsidersag
PostPosted: Sat Oct 13, 2012 6:53 pm    Post subject: Re: DC pressure plate Reply to specific post Reply with quote
I went only for the SC. Cant pass up good deals i guess!!
