| Author |
Message |
toolz Long Time User
Posted: Thu Oct 11, 2012 10:31 pm Post subject: 4020 plastic oil line |
The '68 4020 I'm working on has a small plastic oil line inside the right frame rail that goes from the front of the tractor back to near the brake valves. What would this be for? If it's factory, I'm surprised it's plastic. I need to repair it since it got cut up when the rods exited the block when the engine grenaded. |
| Back to top |
4020deereboy Long Time User
Posted: Thu Oct 11, 2012 10:39 pm Post subject: Re: 4020 plastic oil line |
The line takes oil that leaks from a seal on the main hydraulic pump back to the resivoir / tranny . I think originally was steal or copper. |
| Back to top |
Posted: Thu Oct 11, 2012 11:02 pm Post subject: Re: 4020 plastic oil line |
Thanks for the quick reply! Guess I'm not the only night-owl. If the line was steel or copper, I wouldn't have given it a thought, but being plastic, I thought it may have been added for some reason. Thanks again. |
| Back to top |
Tx Jim Tractor Guru
Joined: 14 Feb 1999 Posts: 13181 Location: Coyote Flats,Tx
Posted: Fri Oct 12, 2012 2:30 am Post subject: Re: 4020 plastic oil line |
IIRC the line(parts ky #4 was plastic way back when I sold them new in the 70's-late80's. I don't remember it ever being steel but I'm old.
AR79714 OIL LINE, PUMP SEAL DRAIN ADD 31.73 USD  |
| Back to top |
tim s Tractor Guru
Joined: 01 Nov 2008 Posts: 5949 Location: Somerset Ohio
Posted: Fri Oct 12, 2012 3:21 am Post subject: Re: 4020 plastic oil line |
The seal drain line was originally steel, then went to a small plastic line ,,then in the mid 70"s Deere went to a larger plastic line that requires 2 adapter fittings (one on each end) |
| Back to top |
Tx Jim Tractor Guru
Posted: Fri Oct 12, 2012 4:27 am Post subject: Re: 4020 plastic oil line |
| Tim S wrote: | | (quoted from post at 07:21:47 10/12/12) The seal drain line was originally steel, then went to a small plastic line ,,then in the mid 70"s Deere went to a larger plastic line that requires 2 adapter fittings (one on each end) |
Dang youth and a good memory are wonderful things of which I have neither. Thanks for the correction,Jim  |
| Back to top |
Posted: Fri Oct 12, 2012 6:26 pm Post subject: Re: 4020 plastic oil line |
Couldn't find any 3/16 plastic line today, so I bought some 3/16 brake line and a couple of brass compression fittings to patch things up. There is obviously very little pressure, so I'm sure it will work. Maybe the steel line will hold up better during the next engine explosion! |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
