JCB 1400b help
Mike Frasier
PostPosted: Fri Oct 12, 2012 5:30 am    Post subject: JCB 1400b help Reply to specific post Reply with quote
I recently purchased a used JCB1400b backhoe. There is a red light on in the top left of the instrument panel. I am also trying to find a basic user/operator manual. I have a service manual but it does not show the controls in the cab or the instrument panel. Thank you for any help.
aarontractorman
PostPosted: Fri Oct 12, 2012 8:19 am    Post subject: Re: JCB 1400b help Reply to specific post Reply with quote
www.cseva.com/THIS PLACE WAS VERY HELPFUL IN GETTING PARTS FOR OUT JCB TELEHANDLER. I TALKED TO MATT IN PARTS. HE WAS ABLE TO GET WHAT WE NEEDED AND GOT IT PRETTY QUICK TOO. IM SURE HE CAN GET YOU A MANUAL AND / OR A SCHEMATIC FAXED OR EMAILED SO YOU BOTH CAN SEE WHAT YOU ARE WANTING. THEY ARE WHO I USE WHEN IT COMES TO JCB. THEY ARE IN CHESAPEAKE VA.
AJ.
PostPosted: Fri Oct 12, 2012 9:44 am    Post subject: Re: JCB 1400b help Reply to specific post Reply with quote
As far as I can recall the red light is for the alternator,it should have the battery symbol on it,if you raise the loader,stop the engine,remove the plug from the back of the alternator,switch on the key,if the light is still on its not the alternator,put the plug back,you can do the same with the oil light,air filter and temperature,check Ebay for a operators manual,good luck with your investment.
AJ
mikefrasier
PostPosted: Sun Oct 14, 2012 9:41 am    Post subject: Re: JCB 1400b help Reply to specific post Reply with quote
Thank you for your reply. The red light on the panel looks like it has fluid on it. I found and checked the levels of the antifreeze and engine oil. They were fine. I also found the hydraulic oil guage and it looks low. I will start there and see if that clears the light. Thanks again for your reply.
mikefrasier
PostPosted: Sun Oct 14, 2012 9:47 am    Post subject: Re: JCB 1400b help Reply to specific post Reply with quote
Thanks for your reply. I will give them a call.
