4020 12 volt batt
Co John s
PostPosted: Fri Oct 12, 2012 6:56 am    Post subject: 4020 12 volt batt Reply to specific post Reply with quote
want to change from two 6 volt bat. to 12 volt bat. will a 4020 diesel start and run with one 12 volt batt. or are two batteries needed? Thanks, John
Tx Jim
PostPosted: Fri Oct 12, 2012 8:33 am    Post subject: Re: 4020 12 volt batt Reply to specific post Reply with quote
2 batteries will be better especially the further NORTH you live.
buickanddeere
PostPosted: Fri Oct 12, 2012 8:42 am    Post subject: Re: 4020 12 volt batt Reply to specific post Reply with quote
When south of the Mason Dixon line in the summer time. And if a hydraulic destroker is used.
TractormanNC
PostPosted: Fri Oct 12, 2012 8:58 am    Post subject: Re: 4020 12 volt batt Reply to specific post Reply with quote
You will get much longer life out of your batteries if you go ahead and put two in it even if you are in a mild climate like I am.
John T
PostPosted: Fri Oct 12, 2012 10:32 am    Post subject: Re: 4020 12 volt batt Reply to specific post Reply with quote
I agree with the other good gents, if it ever gets very cold where you live Id opt for two twelve volt batteries in paralell. In paralell the CCA and Amp Hrs of available stored energy is additive........
John T
Bspauld
PostPosted: Fri Oct 12, 2012 12:08 pm    Post subject: Re: 4020 12 volt batt Reply to specific post Reply with quote
I was under the impression that it depended on the cranking amps. a 1000 cca in a 12 volt has more power then 2 6 volts that have 600 cca. I went to a single 12 volt in my 70 and it cranks faster and longer. We have cold weather here to, it starts below 0
Texasmark1
PostPosted: Fri Oct 12, 2012 2:36 pm    Post subject: Re: 4020 12 volt batt Reply to specific post Reply with quote
This is about a 4010D, not a 26hp big brother. I bought one once and I kid you not the battery was a single trolling motor deep cycle, not combo start/cycle but deep cycle and the farmer I bought it from had been using it for several years. I absolutely couldn't believe it after you read what you are fed by the news media about low cranking currents from regular deep cycles.
I ran the battery for another year or so before I bought a single 12v series 31 HD OTR truck battery.
But I live in N. TX. and winters aren't all that severe.
And that's the truth!!!!!!!
Mark
John T
PostPosted: Fri Oct 12, 2012 2:53 pm    Post subject: Re: 4020 12 volt batt Reply to specific post Reply with quote
In series the CCA nor the Amp hours is additive, only the voltage adds. In paralell voltage is the same while CCA and Amp Hrs adds.
John T
4020_1966
PostPosted: Fri Oct 12, 2012 8:18 pm    Post subject: Re: 4020 12 volt batt Reply to specific post Reply with quote
Co John s,
Look in the 2440 battery thread for my post there on the large single 12v battery I run and guarantee that the 1600 cca battery I have gives me higher cranking voltage (measured at the starter) and faster cranking and more than enough reserve power than I have had with 2 12volt batteries and I never had it slow down in the least cranking my 4020D. The battery was 120$ at teh local farm chain store, I have had it for 2 years now, -10 degrees F did not phase the battery at all when I started it up (and I could not use my block heater so it was totally cold). Run 00 short cables both directly to the starter and you will not be sorry. It is physically larger than 2 of the "skinnies" put together, taller longer and wider. I had 2 high performance skinnies in paralell before this and I can tell a huge differance. Make sure you have a good starter like the 4.0 or 5.0 kw Denso starter. Better batteries on the 2.3kw delco Deere gives you in kits and put on a lot of 12 v engines is like putting perfume on a pig. I put a picture there as well showing my set up.
email if you want more information on what I have set up. just keep in mind two batteries means more cables and connections to corrode, more cost in batteries to buy and replace them, more places for problems. I always try to keep is simple and straight forward.
charles.whitlock@hotmail.com
Bspauld
PostPosted: Sat Oct 13, 2012 3:10 am    Post subject: Re: 4020 12 volt batt Reply to specific post Reply with quote
I understand what you said about 2 12 volts in parallel being better, but if your replacing 2 6 volts with a 12 the 2 6 volts would be hooked in series. I know his 4020 is a lot more engine then my 70 is but on my 70 I found the single 12 volt is better then 2 6 volts in series
John T
PostPosted: Sat Oct 13, 2012 4:35 am    Post subject: Re: 4020 12 volt batt Reply to specific post Reply with quote
Yeah the thing is you have to make an apples to apples comparison. Given all else equal, the more lead and the more plates (about same as more WEIGHT) the more STORED ENERGY. As an example, two light wimpy twelves in paralell may or may not store more energy then two super heavy sixes in series IT ALL DEPENDS ON HOW MUCH LEAD AND ACID N PLATES.
Fun discussion for us sparkies at least lol
Take care
John T
buickanddeere
PostPosted: Sat Oct 13, 2012 4:40 am    Post subject: Re: 4020 12 volt batt Reply to specific post Reply with quote
Compare the cubic inches being squeezed during the compression stroke on the 70 vs the 4020. Then factor in the compression ratio.
Not a whole lot of difference.
4020_1966
PostPosted: Sat Oct 13, 2012 2:36 pm    Post subject: Re: 4020 12 volt batt Reply to specific post Reply with quote
John T, weight does sound like a pretty good idea. For fun I will weigh my battery when I take it out here soon. I bent the case frame some and plan on fixing it. I will measure dad's 12v skinnies too. Pretty curious about how they compare.
Tx Jim
PostPosted: Sun Oct 14, 2012 3:18 am    Post subject: Re: 4020 12 volt batt Reply to specific post Reply with quote
Here's the spec's on the JD 12V battery for a 4020
Part Number: TY24341
Replaces Part: TY21733
Part Price: 165.10 USD
Core Value: (22.50 USD)
End Price With Core Return: 142.60 USD
On Hand: 12 Check Other Stores
Description: BATTERY,HIB.BCI3ET,620CC,120RC,CATD
Specification
Weight 35.23 LBS 15.98 Kg
Voltage 12.000
Standard Group 3ET
Cold Cranking Amps at 0° F (-17.8 °C) 620.000
Cold Cranking Amps at 32° F (0° C) 744.000
Reserve Capacity (Minutes) 25A at 80 °F (26.7 °C) 120.000
Overall Length 19.210 IN
Overall Width 4.270 IN
Overall Height 8.720 IN
Terminal Type_ A
Wet / Dry DRY
Chemistry HYBRID
Elements ANCHORED
Co John s
PostPosted: Sun Oct 14, 2012 9:07 am    Post subject: Re: 4020 12 volt batt Reply to specific post Reply with quote
Thanks for all the info. Leaning towards one batt mounted by starter. thx, John
