| Author |
Message |
Ten-Twenty Regular
Posted: Fri Oct 12, 2012 7:23 am Post subject: JD 800 Hitch |
When adjusting the lift arms on a JD 800 hitch (not an 800A or 801), what is the maximum amount they can be lowered? How many inches of threads need to be left in the housing? |
| Back to top |
Mike M Tractor Guru
Posted: Fri Oct 12, 2012 11:43 am Post subject: Re: JD 800 Hitch |
That's knida an iffy question ? If your threads are in perfect shape then at least as far in as the dia. of the rod I would think as a minimun depth. If the threads are getting sloppy for years of use then they may not hold at any depth ?
Deere did offer an optional adapter to fit up on the upper lift arms to let the lower ones down lower. Listed as for use with a # 20 dirt scoop I believe. |
| Back to top |
wilamayb Tractor Expert
Joined: 30 Jul 2007 Posts: 2596 Location: Union City, TN
Posted: Fri Oct 12, 2012 11:52 am Post subject: Re: JD 800 Hitch |
Werent there some pieces to lengthen the lift links if used on the 70 tractor?
Check the PC on that one...I think Im right on that one... |
| Back to top |
Bob Harvey Tractor Guru
Posted: Fri Oct 12, 2012 1:31 pm Post subject: Re: JD 800 Hitch |
Just a WAG, but I would think (due to age and wear) 1 1/2"-2" of thread IN. Your choice. If in good shape 1" would probly do it. HTH |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
