Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
1963 MF35 Elecetrical system
Post new topic    Yesterday's Tractors Forum Index -> Massey Harris & Massey Ferguson
GaryinAL
PostPosted: Fri Oct 12, 2012 8:05 am    Post subject: 1963 MF35 Elecetrical system Reply to specific post Reply with quote
I was looking at my Father-in-law's MF35 the other day and noticed that it had been converted from a generator to an alternator. I also noticed that it had a ballast resistor wired into the wire going to the coil. Tractordata.com list the MF35 gas tractor as a 12 volt system. Should this even have a resistor on it if all they did was convert it to a 12 volt alternator? Also, wouldn't this affecting how well it runs, if the resistor is cutting the number of amps going to the coil? I'm thinking he thought it was a six volt system.
Thanks for your comments.
Gary
Gearhead210
PostPosted: Fri Oct 12, 2012 8:29 am    Post subject: Re: 1963 MF35 Elecetrical system Reply to specific post Reply with quote
The voltage will not necessarily determine whether the resistor before the coil is needed. In 12V coils there are External resistor and internal resistor models. It may have stamped on the coil somewhere which type it is, but it is not uncommon for a 12V to have in inline resistor. Is there an issue with how it is running currently?
GaryinAL
PostPosted: Sat Oct 13, 2012 8:45 am    Post subject: Re: 1963 MF35 Elecetrical system Reply to specific post Reply with quote
Yea, It seems to want to kind of smother out when under load. Wanted to check the obvious first. Never seen a resistor with a 12 volt system. I know I need to check carb, timing, plugs, distributor, etc. What order should I check these things?, or does it matter, as long as I check them?
Gearhead210
PostPosted: Sun Oct 14, 2012 4:27 am    Post subject: Re: 1963 MF35 Elecetrical system Reply to specific post Reply with quote
Something that will "help" direct you to look towards electrical or towards fuel, is when it starts to act up while running it pull the choke part way out. If it starts running better then you have a fuel issue. No change, then it's electrical. Something simple I would check if you think its a fuel issue is for good flow down to the carb. Possible electrical issues that could cause it to get worse when hot is a bad coil or bad condenser. Check to see if the points have a bad burn spot on them- the condenser can cause that. If coils are bad they usually act up when warm, could have a break in the wire internally that turns into a gap when warmed up and everything expands.
GaryinAL
PostPosted: Mon Oct 15, 2012 12:42 pm    Post subject: Re: 1963 MF35 Elecetrical system Reply to specific post Reply with quote
Gearhead210 wrote:
(quoted from post at 13:27:17 10/14/12) Something that will "help" direct you to look towards electrical or towards fuel, is when it starts to act up while running it pull the choke part way out. If it starts running better then you have a fuel issue. No change, then it's electrical. Something simple I would check if you think its a fuel issue is for good flow down to the carb. Possible electrical issues that could cause it to get worse when hot is a bad coil or bad condenser. Check to see if the points have a bad burn spot on them- the condenser can cause that. If coils are bad they usually act up when warm, could have a break in the wire internally that turns into a gap when warmed up and everything expands.
Thanks for the info. I will try those things next time I'm at the tractor.
