Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
part No for hollow bolt that holds sediment bowl to carb?
Goto page 1, 2  Next
Post new topic    Yesterday's Tractors Forum Index -> Ford
William Fissell
PostPosted: Fri Oct 12, 2012 8:28 am    Post subject: part No for hollow bolt that holds sediment bowl to carb? Reply to specific post Reply with quote
Hi, All,
changing out the online fuel filter for the original-style sediment bowl on my 640. I have the sediment bowl but not the 3/8 hollow bolt that attaches it to the carb.
can't find the part on this site, only on CNH. Wanted to check before I went to CNH.
thanks!
Bill
Dean
PostPosted: Fri Oct 12, 2012 8:31 am    Post subject: Re: part No for hollow bolt that holds sediment bowl to carb Reply to specific post Reply with quote
The banjo bolt is CNH only.
Dean
William Fissell
PostPosted: Fri Oct 12, 2012 8:41 am    Post subject: Re: part No for hollow bolt that holds sediment bowl to carb Reply to specific post Reply with quote
thx. Banjo?
6t6cuda
PostPosted: Fri Oct 12, 2012 9:00 am    Post subject: Re: part No for hollow bolt that holds sediment bowl to carb Reply to specific post Reply with quote
Banjo is a common name for this type of bolt.
They are used on brakes as well, so (not sure) it might be worth looking at the "help" section of your local autoparts store - they may not be long enough.
It should be easy enough to make if you had to. Just remember to start with a grade 2 bolt or you will have fun trying to drill it...
awhtx
PostPosted: Fri Oct 12, 2012 10:04 am    Post subject: Re: part No for hollow bolt that holds sediment bowl to carb Reply to specific post Reply with quote
Part Number 86531362, $20.02 at Messick's.
William Fissell
PostPosted: Fri Oct 12, 2012 10:35 am    Post subject: Re: part No for hollow bolt that holds sediment bowl to carb Reply to specific post Reply with quote
thanks! I can;t seem to mail order form the CNH site, though I could almost be certain I did once before.
Dean
PostPosted: Fri Oct 12, 2012 11:16 am    Post subject: Re: part No for hollow bolt that holds sediment bowl to carb Reply to specific post Reply with quote
Not possible. You must order through a CNH dealer.
Dean
souNdguy
PostPosted: Fri Oct 12, 2012 1:02 pm    Post subject: Re: part No for hollow bolt that holds sediment bowl to carb Reply to specific post Reply with quote
ditto that.. just 90% center drill then cross drill a gr2 bolt.
RickB
PostPosted: Fri Oct 12, 2012 1:43 pm    Post subject: Re: part No for hollow bolt that holds sediment bowl to carb Reply to specific post Reply with quote
Most fittings that banjo bolts fit through resembles the musical instrument. Doesn't necessarily apply to this application.
Royse
PostPosted: Fri Oct 12, 2012 1:49 pm    Post subject: Re: part No for hollow bolt that holds sediment bowl to carb Reply to specific post Reply with quote
I did a Google search and found that part number on just 8n's for a $17.50 if it helps.
Gaskets for it sold separately.
awhtx
PostPosted: Fri Oct 12, 2012 2:44 pm    Post subject: Re: part No for hollow bolt that holds sediment bowl to carb Reply to specific post Reply with quote
I'll make them and mail them to anybody that needs one for $12.50 each, postage included.
Scott PA
PostPosted: Fri Oct 12, 2012 4:59 pm    Post subject: Re: part No for hollow bolt that holds sediment bowl to carb Reply to specific post Reply with quote
NewHolland only has the hollow bolt anymore for the 1958-1964 small diameter sediment bowl, unless that is what you are installing on you 640, the cross drilled hole is at a different location between the two and it will starve for fuel if you do not keep them matched.
36 Coupe
PostPosted: Sat Oct 13, 2012 3:34 am    Post subject: Re: part No for hollow bolt that holds sediment bowl to carb Reply to specific post Reply with quote
You need 2 copper or fiber washers on each side of the sediment bowl.I drilled the center hole deeper and drilled a new cross hole on mine.I made all the measurements and offered to post them.No interest.Cant see paying twenty bucks for a part you can make for twentyfive cents.You do need a drill press and vise.I put all the measurements in one of my notebooks.Now if I can find it Ill make you one for postage cost.I spent 10 minutes modifying my bolt so making a new one should take about the same time.
36 Coupe
PostPosted: Sat Oct 13, 2012 3:36 am    Post subject: Re: part No for hollow bolt that holds sediment bowl to carb Reply to specific post Reply with quote
Too much money for a 10 minute job.
wayne-N-Ind.
PostPosted: Sat Oct 13, 2012 5:15 pm    Post subject: Re: part No for hollow bolt that holds sediment bowl to carb Reply to specific post Reply with quote
36coupe I like your price on the bolts. I have a 860 & I changed the carb. not sure I have the right bolt.it did have a large carb on it. it isa ford Industial eng.
Goto page 1, 2  Next
Page 1 of 2
