| Author |
Message |
williamp New User
Posted: Fri Oct 12, 2012 9:58 am Post subject: 981 SOS No power to Rear Wheels |
Dad was Brush hogging a pasture and suddenly lost forward movement. Gear selector moves normally. Had to turn disengagement nut to roll tractor onto trailer. I"m not much of a mechanic and closest shop with tools to work on the SOS is more tnan a hour and a half way. Any ideas on potentail cause and suggested fix? Help is greatly appreciated. |
| Back to top |
awhtx Tractor Guru
Joined: 16 Jan 2002 Posts: 5048 Location: Lampasas, TX
Posted: Fri Oct 12, 2012 10:06 am Post subject: Re: 981 SOS No power to Rear Wheels |
Low fluid level?
Stripped the splines on the input shaft and/or the clutch disc? |
| Back to top |
Larry NCKS Tractor Guru
Joined: 23 Dec 2001 Posts: 3711 Location: Washington, KS/Lincoln, NE
Posted: Fri Oct 12, 2012 10:17 am Post subject: Re: 981 SOS No power to Rear Wheels |
did the PTO quit too? if so, conditions as awhtx outlined. If not, internal transmission failure. |
| Back to top |
williamp New User
Posted: Fri Oct 12, 2012 2:23 pm Post subject: Re: 981 SOS No power to Rear Wheels |
PTO working, Fluid level full, 3 point works, remote hydraulics raise and lower modifified dearborn dozer blade I use to plow snow. |
| Back to top |
awhtx Tractor Guru
Posted: Fri Oct 12, 2012 2:38 pm Post subject: Re: 981 SOS No power to Rear Wheels |
If the PTO is working the input shaft/clutch splines are not stripped. However, the fact that the 3PH and remote hydraulics work has nothing to do with the transmission. They work off of a completely separate hydraulic system than the transmission. You need to check the fluid level in the transmission itself. There is a square head plug in the side of the transmission to check the fluid. |
| Back to top |
ZANE Tractor Guru
Posted: Fri Oct 12, 2012 4:48 pm Post subject: Re: 981 SOS No power to Rear Wheels |
I have seen the pump line to the control valve array break and loose all function.
Probably the PTO would quit too though????
Zane |
| Back to top |
mooger Regular
Posted: Fri Oct 12, 2012 8:35 pm Post subject: Re: 981 SOS No power to Rear Wheels |
The main hydraulic tube broke in my 671 and, although the tractor wouldn"t move, the PTO shaft still turned when the engine was running.
Without oil pressure because of the broken tube, it was still the typical SOS condition where the PTO shaft always rotates - input shaft geared to front PTO shaft/clutchpak/rear PTO shaft and enough friction in the clutchpak to overcome any resistance by shaft bearings. |
| Back to top |
Posted: Sat Oct 13, 2012 5:07 am Post subject: Re: 981 SOS No power to Rear Wheels |
There would be a huge difference of possibilities here if the PTO is just coasting under no load. I'm assuming that this PTO is still driving his bush hog??????? |
| Back to top |
James Trovillion Guest
Posted: Sun Oct 14, 2012 5:09 am Post subject: Re: 981 SOS No power to Rear Wheels |
The transmission has lever to allow the tractor to be towed, check and see if lever got struck and moved. this would cause tractor to have no power to differential |
| Back to top |
Sean in PA Tractor Expert
Joined: 27 Feb 2008 Posts: 1672 Location: Southeast PA
Posted: Sun Oct 14, 2012 6:04 am Post subject: Re: 981 SOS No power to Rear Wheels |
| James Trovillion wrote: | | (quoted from post at 09:09:07 10/14/12) The transmission has lever to allow the tractor to be towed, check and see if lever got struck and moved. this would cause tractor to have no power to differential |
From the original post:
| Quote: | | Had to turn disengagement nut to roll tractor onto trailer. |
I take this to mean that after the problem started that the tractor wouldn't roll until he disengaged the traction disconnect. |
| Back to top |
Posted: Sun Oct 14, 2012 9:02 am Post subject: Re: 981 SOS No power to Rear Wheels |
| James Trovillion wrote: | | (quoted from post at 08:09:07 10/14/12) The transmission has lever to allow the tractor to be towed, check and see if lever got struck and moved. this would cause tractor to have no power to differential |
x2 what sean said. This bridge already collapsed before you got to it. You fell in the river andgot wet!  |
| Back to top |
YT Home
| Tractor Manuals
| Tractor Parts
| Forum Home
