Tractor
 Parts
Yesterday's Tractors
Tractor Manuals
Shop for Parts:
Project Journal
Tractor Town
Show & Pull Guide
Related Sites
The Tractor Shed
TractorLinks.com
Ford N-Series Club
Garden Tractors
Today's Tractors
Classic Trucks
Kountry Life
subscribe
unsubscribe
Content Guide
Picture List - TOC
Ad Archives - TOC
Manuals - TOC
1958 310B Front Loader Valve
Post new topic    Yesterday's Tractors Forum Index -> Case and David Brown
RGV hay
PostPosted: Fri Oct 12, 2012 12:04 pm    Post subject: 1958 310B Front Loader Valve Reply to specific post Reply with quote
I have a Case front loader on a 1958 310B; the front loader ID plate reads Model Number 4032659, although I suspect that this may be the serial#. Its hydraulic pump is driven from the front of the engine. It has a Gresen Minneapolis FO, 2 spool loader valve with float. The bucket tipping spool has begun to bind up. I don't have the schematic or breakdown of this valve; therefore I need it or advice on how to disassemble the spool to check o-rings, springs or whatever may be binding.
Case Nutty 1660
PostPosted: Fri Oct 12, 2012 12:46 pm    Post subject: Re: 1958 310B Front Loader Valve Reply to specific post Reply with quote
this is from a 420B parts but should be the same as it's little brother the 310B cnt
RGV hay
PostPosted: Fri Oct 12, 2012 3:00 pm    Post subject: Re: 1958 310B Front Loader Valve Reply to specific post Reply with quote
Thank you for the breakdown. It appears to be the same as the 420B except it is upside down on the 310B, mounting under a horizontal plate. Would you happen to have the parts list? Thanks again!
RGV hay
PostPosted: Fri Oct 12, 2012 3:05 pm    Post subject: Re: 1958 310B Front Loader Valve Reply to specific post Reply with quote
Thank you for the reply; it appears to be the same as the 420B other than it is upside down on the 310B, attached to the underside of a horizontal plate. Would you happen to have the parts list? Thank you again!
Case Nutty 1660
PostPosted: Fri Oct 12, 2012 3:12 pm    Post subject: Re: 1958 310B Front Loader Valve Reply to specific post Reply with quote
here ya go cnt
DKase
PostPosted: Fri Oct 12, 2012 6:47 pm    Post subject: Re: 1958 310B Front Loader Valve Reply to specific post Reply with quote
Take the caps off the front end of the spools to start with. (opposite end as the handle) There is a screw in there with washers and a spring, I have seen the screws loose, and broken springs that will cause what you explained. Simple fix if that is the problem.
RGV hay
PostPosted: Sat Oct 13, 2012 5:24 am    Post subject: Re: 1958 310B Front Loader Valve Reply to specific post Reply with quote
Thanks, I prefer simple. I'll post what's in there after the weekend.
RGV hay
PostPosted: Sat Oct 13, 2012 2:47 pm    Post subject: Re: 1958 310B Front Loader Valve Reply to specific post Reply with quote
Turned out to be grunge in and around the spring, more than likely from the missing rubber caps on the spring end of both spools. Thanks for the insight!
RGV hay
PostPosted: Sat Oct 13, 2012 2:52 pm    Post subject: Re: 1958 310B Front Loader Valve Reply to specific post Reply with quote
Thanks again; I went into the bucket tipping spool this afternoon and found grunge around the spring probably from the missing rubber caps which the pictorial brought to light. Works fine now, thanks!
